Question about West Bend 84323 Slow Cooker
I accidently set my cooker on a electric stove burner and melted the cord that is the power for my cooker. Where do I go to get a new cord replaced???
I want to order an elite pressure cooker cord mine got lost
Gwen, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Your AC Power Cord Connection Electric Cord Sets
http://www.powerpressurecooker.com/parts-and-accessories.php
Appliance Cords
CORDS small appliance cord sets electrical cords vacuum cords
Mar 03, 2016 | Crock Pots & Slow Cookers
I need a new electrical cord for my crock pot.
These should be available from any electrical shop. Very often even kettle cords will fit crockpots. Take the old cord with you when you shop.
Nov 21, 2015 | Crock Pots & Slow Cookers
Can I replace cord on Corningware cooker.
Yes you should be able to replace this cord.
Start by a/ Getting the size of cord required, is it 1.5 or 2.5mm conductor size. Check the manufacturers rating plate to see wattage/power rating of the cooker.
b/ Check the cord, is it heat resisting type??
c/ Cut a piece off and take it to local diy electrical shop to get correct rating and type.
d/ ALWAYS SWITCH OFF BEFORE CHECKING ANYTHING.
Dec 01, 2014 | CorningWare Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Rice cooker retractable cord burned.
    If the mechanical part is still good then any handy person can replace the cord with any purchased cord but to do so safely it would be best to have someone with electrical training to do so
    Nov 24, 2013 | Cuisinart PSC-650 6.5-Quart Slow Cooker
    How do I make coffee in the corning ware coffee pot? It is the top of the stove maker and does not have any electrical cord.
    This is a stove top percolator and you can use the great directions here:
    http://www.talkaboutcoffee.com/how-to-make-coffee-in-a-percolator.html
    Nov 19, 2009 | CorningWare Crock Pots & Slow Cookers
    West Bend slow cooker
    There is a website that carries cords for "All Round 4qt. Cookers" Price $3.99 from Focus Electrics.
    The link is below:
    http//www.focuselectrics.com/catalog.cfm?dest=dir&linkid=101&linkon=catagory
    Oct 15, 2008 | West Bend Crock Pots & Slow Cookers
    Rival crock pot
    Yes, it's not unusual for the outside to be too hot to touch. A slow cooker won't get as hot as a bare burner on the stove, but it still gets hot enough to cook meat. The outside has a bit of insulation, but it still may get hot enough to cause pain, melt a bread bag, etc. Be sure and place it where no one will accidentally touch it.
    Jul 16, 2008 | Rival 38501 Smart Pot 5-Quart
    West Bend 84323 Slow Cooker Logo
    12 people viewed this question
    Top West Bend Crock Pots & Slow Cookers Experts
    Steve
    Lawrence Oravetz
    Andrew Taylor
    Andrew Taylor
    Are you a West Bend Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
