Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
T0p load washer wont cut water off after it fills?
  • 5,911 Answers
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. Before assuming you have a defective pressure switch, however, read the following link:
http://www.fixya.com/support/r762094-washer_overflows
In many cases the small air hose comes loose from the pressure switch and causes the symptoms you are experiencing. Check the air hose to ensure it is still attached to the pressure switch and check the electrical connections to ensure they are not corroded. If these preliminary measures do not work, replace the pressure switch. If the pressure switch requires replacement, you can search for the best price at these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Sep 25, 2009
  • Jeff Rockwell
    Jeff Rockwell Sep 26, 2009
    The last sentence I wrote stated, "If you have questions, or require additional assistance, please let me know". If the solution I provided didn't help, or if you didn't understand the instructions, you could have asked for clarification, or additional help instead of leaving an adverse rating.
I have a Samsung top load washer #WA5451ANW. Will only fill with water. Had to turn the power off so machine would stop filling with water.
Possible that the cut off to the Inlet valve has failed which means that the controller unit is a suspect. Also if the inlet valve is staying ON even when the power is cut off , then it is a case of inlet valve failure.
Dec 31, 2012 | Samsung WA5451ANW 4.7 Cu. Ft. White...
The water won't cut off inside our whdse820 GE washer. I've stopped the cycle and cut off the water. Little help?
the water valve solenoid on the rear apron that opens the water valves electrically to fill the washer is bad and is not closing to shut water off
Oct 23, 2010 | GE WWSE5200B Top Load Washer
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
GE top loader washer water keeps running will only cut off at faucets"
If disconnecting power does not stop the water fill, replace the washer's inlet water valve. It is the part the fill hoses screw onto on the back of the machine.
May 20, 2009 | GE WBSE3120B Top Load Washer
Wash cycle not filling with water
Does the washed show an error?
Check all hoses in back. Remove them from washer and ensure water is coming from lines (drain into bucket).
Unplug washer for several minutes, then try again.
May 02, 2009 | LG WM2487H Front Load Washer
The washer is very slow to fill up with water.
cut the water off to the fill hoses,,than remove fill hose and clean water inlet vavle screens with tooth brush..onthejob
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
116 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
