Question about Dragon Quest Swords: Masked Queen and the Tower of Mirriors for Nintendo Wii
Sometimes when i am playing a stage, My play gets slower. Usually when i am in the red sea or using figure og fate. Then it kinda getting slow. And it react slower. Do you think it's because of the monsters?
Plays so slow - how to fix?
dear
i need you to check the rubber belt which is connected on the top of DC motor if it's get wider than the original size you have to change it
Aug 04, 2015 | Sanyo Trc 8800 Full Size Tape Transcriber...
When I record a video using my Nikon Coolpix s4000, when I try to play it back the sound plays at normal speed but the picture is in slow motion! This happens everytime I record a video, is there anything...
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
Jul 29, 2011 | Nikon Coolpix S4000 Digital Camera
What gear should i drive in snow and ice
Depends, do you have 4 wheel drive? If so you can just use 4 wheel high, or if things get really slippery, use 4 wheel low and go slow, both in the drive position on the transmission shifter.
If 2wd, just use drive and go slow, again, if it gets slippery out, you can shift down in gears to go slower and to keep your speed slow.
If you're talking about snow and ice on just streets, then stick with 4 wheel high with 4x4, or "drive" in 2wd. You typically don't want to switch to 3,2, or 1st gear at highway speeds.
If you're playing in the snow, just use 4x4 high until you get stuck, then switch to 4 low to get out.
The only time I switch gears with the transmission (from drive to 3,2, or 1) is when I want to go really slow and keep it there. However, when I "play" in the snow, it's Drive only.
Does this answer your question? If not, let me know! Thanks
Jan 11, 2011 | 2003 Chevrolet TrailBlazer
My Sea&Sea 860g will not focus anymore?
I realize most of these questions are kinda old, but I just fixed my Sea & Sea 860g focus problem and figured I should post what I did. The camera just stopped fucusing one day and I have tried everything, reinstalling the firmware, resetting the settings, playing with everything imaginable. Finally, out of frustration, and literally on my way to the trash can, I physically pushed the lens in about 1/2 an inch and turned it off. Since I had pushed it "out of gear" or something, the lens just floated free until I pushed it all the way in and turned it back on. Once It came back on, it must have recalibrated itself or something, the focus snapped in and now it works fine again... I had even emailed Sea and Sea for a fix and they said to just throw it out, nothing could be done, HA. Hope anyone else with this problem sees this, I know its very common for those camera.
Good Luck,
Chris
Sep 30, 2010 | Sea and Sea DX-860G Digital Camera
Compatibility issues iPhone 3G - JBL On Stage IIIp
hi there, believe it or not, apple has put a authentication chip into newer devices. It won't allow you to play music or display video on devices that are old. Apple wants you to go out and buy new accessories for the new stuff to make more money. My suggestion is to sell it on eBay and use the money to get a newer compatible dock with your iPhone.
Feb 17, 2010 | On Stage Stands JBL On Stage IIIP Portable...
When I try to watch a video it will play a few seconds then stop then will play again for a few seconds what can i do
this happens if you have a slow internet connection...
There is a high demand for the video
your video card is not up to snuff...
cheap fix... pause the video and wait till the red bar is all the way to the right or full...
then play...
if that still doesn't work then
upgrade memory... and do the pause trick
still doesn't work... upgrade video card and try pause trick...
still doesn't work... get a new computer...
Feb 06, 2010 | YouTube Videos
How to transter music tracks from my mini disc collection on to my windows vista premium hard drive. i have a sony HD Mz rh1 player with sonic stage software but even when i try to down load the newer...
2 ways to do this both will be and take real time...in both cases you will need to connect disc player to pc...play ...(upload files to pc) audacity is a great software for this purpose...tag your files (artist name, track name, album name,yr ,track number and genre)...remember I said 2 ways you do this...1 play the whole disc or #2 a track at a time both using optical cable..note the ladder is best you can tag your files
Oct 15, 2009 | Sony Walkman® MZ-RH1 Personal MiniDisc...
Hp games unlock codes
It will not provide you cause of serial numbers or any link of keygen.
May 29, 2009 | Microsoft Windows Vista Business Edition...
Need free unlock code for hp game fate
unlock code for fate -> TEF7-4H9E-LCBR
if u find ne other mail me on ankitsharma.220@gmail.com so that i can help others
Jan 10, 2009 | Computers & Internet
Slow Playback
First try using a dvd cleaner. It's possible that dust got on the lens from the inactivity. The DVD should not be ruined but try cleaning before using again. Hope this helps.
Dec 20, 2008 | LG DN788
Dragon Quest Swords: Masked Queen and the Tower of Mirriors for Nintendo Wii Logo
21 people viewed this question
Top Dragon Video Game Consoles & Games Experts
James Wishart
Are you a Dragon Video Game Console and Game Expert? Answer questions, earn points and help others
