Question about Hitachi DZBX35A DVD Camcorder
Where can I buy another battery charger for my
I need another battery charger for my camcorder, where can I go and buy one?
Need a battery charger
Best place to buy something like that would be ebay...I'm a professonal photographer, and that's where I get all my needs.
Mar 19, 2010 | Mitsuba DV9002 Flash Media Camcorder
Vupoint dv-dv1-vp camcorder needs a new battery
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any working usb port.
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
Tip
You can buy replacement laptop battery from our site:www.buy-battery.ca We...
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on May 27, 2010 | Computers & Internet
My hitachi camcorder says I need an AC adapter/charger
Hi Riannasmail,
You need a camcorder to charger DC cable,it looks like a battery with a trailing cable that has a DC plug on the end that plugs into the Hitachi battery charger.If you are in the USA you should be able to buy one for about $8 to $12,if you live in UK you will be ripped off at about £24.
I made my own adaptor and charger system for less than £20,If you need more info please contact me.
Oct 14, 2009 | Hitachi DZ-MV750MA DVD Camcorder
This camcorder was gifted to me recently and comes with an inbuilt battery. however i dont knw much about camcorders. i dont have a charger for this and dont know where is the socket for charging on the...
Yes it is the dc socket that you will use to charge your battery . It charges right on the camcorder itself with your ac adaptor . make sure the camcorder is in off postion for it to charge.
Larry
Jul 10, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
I need a battery and a charger, where do I buy one
(http://www.ebatts.com/quasar_vm-l153_camcorder_accessories.aspx) Copy this web page address and paste it into the address bar of you browser. It will take you to a page that sells the a/c charger and battery for the Quasar VM-L153 camcorder. You can also call the Panasonic customer support parts and accessories telephone at 1-800-332-5368. Between the hours of 6am-5pm M-f PST. Give them the brand name and model number of the camcorder and these part numbers 1. PV_A20 for the a/c charger 2.HHR-V60A/1B for the 6hr battery 3.HHR-V40A/1B for the 4hr battery. 4.HHR-V20A/1B for the 2hr battery. They will be able to give you prices and availability for the parts you need. I hope this information helps you solve your problem.
Jun 04, 2009 | Quasar VM-L153 VHS-C Camcorder
Need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
Nov 18, 2008 | RCA CC6254 VHS-C Analog Camcorder
Battery charger for a JVC GR AX230 camcorder
All I wanted was to buy a charger, so I don't need your help. I found one. thanks.
Jul 18, 2008 | JVC GR-AX230 Camcorder
Regarding DXG-305V
There is no way you can charge it. You can buy a battery charger so you can put battery in the charger and not waste money buy another batteries again. Buy a battery that can charge. You cannot buy battery that are not support battery charger. sometime it will cause explosion
Dec 26, 2007 | DXG Technology DXG-305V Digital Camera
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Hitachi DZBX35A DVD Camcorder Logo
13 people viewed this question
Top Hitachi Video Cameras Experts
PNiss
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
