Question about Yahoo Mail
Connection speed is very slow all other fuctions are very slow for the first 10 min after I turn on computer. please solve.
When i turn on my lenovo 5000 y500 laptop very slow booting takes place
There are so many reasons can cause a Lenovo computer running slow at boot up, it is hard to identify just what might be dragging down your Lenovo's performance, let alone implement the necessary technical adjustments to fix it.
So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software, available here: http://www.speeduplenovo.com/
Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
Aug 04, 2012 | E-Machines eMachines Refurbished EMA...
My candence Dx10 slows down after using for a 10 min or so
Dear Sir:
You must need to adjust the sensor speed, by that reason Please RUN the software calibration Inmediately for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnose and troubleshooting.
Sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Mar 06, 2012 | Treadmill Doctor Weslo Cadence Dx10...
Annoying Wireless network connection problems!
Try changing the channel number in the router for the Wi FI add 3 to the minimum channel number.
It is possible you have a neighbour with wi fi and by adding three to the channel number you give some space separation to allow more bandwidth on the WI FI channel.
when this slow down occurs ping the router address (default gateway ip) and see if ping is quick. This will eliminate WI FI as slow point. Try using tracert instead of ping to see if bottlenecks occur in network or internet.
Mar 06, 2017 | Computers & Internet
The conection freezes up and looses important work without saving it and it moves real slow. Had computer checked and was told it was the conection.can this be fixed or do i need an upgrade. loss of m
There maybe several explanations for the freeze ups,but I think the major one lies with your internet services connections.Whats the speed of the connection?How's the networks availability?Try this and see what happens:-
  • Uninstall and reinstall the browser[firefox]
  • Set firefox as the default browser.If still freezes;-
  • Choose another network for the internet connections.
Hope this helps.Thanks!
Oct 20, 2011 | HP Computers & Internet
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
.Sir , I am having Huawei
dial-up is very slow mode of internet connections, you may need DSL connection for high speed internet however
for speed up your dial-up connection you may visit this site for guidance
http://www.trilliumfoundation.org/cms/en/dial_tips.aspx
Nov 22, 2010 | Computers & Internet
Flashing green light on power supplyonly fans come on at start up
just open ur pc case replace the ram and all connections for 5 to 10 min clean dust inside pc and also clean ram and put back in to pc and restart i hope ur comp will be right back to normal!
Aug 02, 2010 | HP (152769-001) (152769001) 250-Watt Power...
Very slow and intermittent wireless internet connection
I seem to have solved the problem by downloading the driver from Asus directly.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I pulled out my Asus card, looked up the card model and downloaded the correct driver. Looks like the windows update or the Dell update must have caused the driver to get whacked. Hope this fixes your issue as well.
Apr 02, 2009 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
Slow computer and locks up
Suggestion:
Go to Start -> Run and type msconfig
Select the startup tab and uncheck anything you don't need.
Click OK and reboot.
Dec 12, 2008 | Computers & Internet
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Yahoo Mail Logo
12 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
