Question about Troy Bilt 5.5hp Self Propelled Mower
We just got a new mower. The 1st we used it it
We just got a new troy mower. The 1st we used it it started right away. It has got worse since we have had it 6 weeks today I can not even get it to start. We have had it in the shop once already. This is ridiculous what is the problem. We have already been told new gas is a must. We have done that.
  • 437 Answers
Depending what type of carburetor is on the mower, it may need to be rebuilt or a new diaphragm to help pump fuel. Plus check replacing the air filter, If it is paper filter, change it, If it is foam clean it out with soap and water and dry it out before putting it back in.
Also try a product called "Seaform" in your gas, you can get it at an automotive supply store.
Posted on Sep 25, 2009
Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Apr 17, 2010 | Garden
My Troybilt starts, idles, then stops. What is
1st thing to try is clean and rebuild carb(easy job) ...good luck
Apr 07, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My Troy-bilt Storm 7524 snow blower goes off after 10min running
it sounds like it may be you armeture[coil], it heats up and stops.
Dec 11, 2009 | Garden
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mower Running Very Poorly
Before I got into the carburetor, I would let all the oil burn out. It's mostly in the muffler and no, that didn't hurt the cylinder/rings. I would put a new sparkplug in as that one is oil fouled. See how it runs. I would change the oil to make sure no fuel seeped into the crankcase. It may need a carb cleaning, especially if you weren't using a fuel stabilizer (such as STA-BIL).
May 28, 2009 | Troy-Bilt Pony Garden Tiller
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Model Series 860
sounds like a bad tranny if this unit is under warentty DO NOT ATTEMPT REPAIR . if you attempt to repair this yourself you can void any warrenty
Sep 19, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
44 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
