Question about Philips Senseo HD-7810 Coffee Maker
The light flashes very fast and nothing I do slows it down. I've tried re-seating the water compartment, but it doesn't work. When the light flashes like this, I cannot make coffee.
  • 11,896 Answers
Unplugg for a few hours. Make sure to press the power button while unplugged to drain any power left inside. Meanwhile, check for any clogs or kinks in the line. The capacitors in the electrical units do tend to get overheated at times and need to cool off.
Posted on Sep 25, 2009
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
Dec 29, 2013 | Keurig B60 Coffee Maker
Pride Motor Chair 2008 Vr2 Controller Speed adjustment lights go to fast setting but chair barely crawls along!
Great question! The slow flash is indicative of a speed reduced mode on models designed for a seat lift option. If the controller detects that the seat is elevated then the speed is reduced - regardless of what you try to do at the joystick.
First - try lowering the seat to its lowest position.
If this doesnt work then look for a bad or disconnected sensor switch on the seat post. There are two leads at a 2-pin plug that are not making a connection when the seat is lowered - causing the controller to sense the chair is not safe to drive fast.
Nov 08, 2013 | Health & Beauty
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Red light flashing fast
The main reason for the Fast flashing red is with the water flow meter.
located at the back part of the machine below the power connector - its functionality can be checked in diagnostic mode .
see attached pictures
its either stuck due to in proper descaling or have corrosion in the connector contact of the flow meter.
You can fined the full service manual at Partsguru
http://www.partsguru.com/user/SERVICE%20MANUAL%20TALEA%20ODEA%20REV.03.pdf
Jul 24, 2013 | Saeco Odea Giro Plus Coffee Maker
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My soothing motions glider isnt moving at all ?
The terminals are probably still a little corroded from whatever you had to clean out earlier, with was more than likely battery acid. Get a few q-tips, hydrogen peroxide, a small bowl of water, and a dry rag.
First, brush out any dry stuff you can see. Those keyboard air cleaner things work great.
Get the end of one q-tip wet with the hydrogen peroxide (not dripping wet) and start on the "+" end of the battery slots. Just work on one slot at a time. After you rub the q-tip around , start on the "-" side or the side that has the spring in it. This is a little harder because you need to gently clean between the coils. Use the other end and remove everything the q-tip will remove.
After you've cleaned one slot, use either another clean q-tip or your rag to wipe it down with the water. Lightly dry it off, then move on to the next slot.
After you've done the entire compartment, check the cover plate too and clean it as needed. Leave it all out in the air overnight to dry completely before trying to do anything with it.
It might not work right away if there was a battery leak and it got back into the electronics a little. Don't be sad if it doesn't work right away, let it sit another day (with no batteries in it) and try it.
If it still doesn't work then the problem is deeper down into the glider's electronics, in which case you might try calling the manufacturer. Fisher Price has a pretty nice customer service department if you can wait through the "on hold for the next available" stuff. They have been able to suggest some strange things for me that got my baby's favorite things to work again. Post again if you still need help, I've cleaned a lot of battery compartments!
Sep 12, 2012 | Fisher Price Soothing Motions Glider Baby...
My Dell D600 laptop stopped working today. Coincidentally, I had just turned it off to try running a test on the RAM because the PC had been slow and locking up for the past month or so. Anyway, when I...
try this:
1- deattach the RAM , run the laptop without (RAM) you must hear som beeps
2- put the ram back again in the same slot
if it doesn't work try other slot
Feb 07, 2012 | Dell Computers & Internet
When i turn on the machine the "!" flash fast constantly and the "drop"light turn on; i turn the nob for the hot water but nothing comes out no water or steam...nothing works..i can hear the engine runnin...
It is telling to purge the air in the water line. Make sure there is no filter in the water tank and turn on the knob. The pump should **** the water and let it out from the steam arm.Hope it works.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
Sony kv32fs13 No Picture or sound stand by light flashing
try to resolder back the pcb some part is loose connection
Dec 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Passenger seat won't go back
I have had the same problem. It occurs when you take the key out of the ignition to fast. Sounds stupid but if you turn the engine off and slow down the extraction of the key the seat will move as it should. I was turning off and taking the key out fast and the seat would not retract. Slowed everything down and now it works. Hope this works for you.
Oct 14, 2008 | 2004 Buick Rainier
Philips Senseo HD-7810 Coffee Maker Logo
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
