Question about VIDAR Systems VIDAR TruScan Titan II
I need a replacement lamp for my p851 Titan II 40" scanner.
    President:
  • 3,085 Answers
I need an instructions manual for the Titan 40 cm petrol chainsaw?
Try Googling (titan)(40)(manual) without parens.
Mar 15, 2018 | Garden
Is replacing the Body Control Module on a 2004 Nissan Titan as easy as removing the old one and plugging in the new one?
The answer to your question is no, The BMC controlled directly by the BMC are.
1. Power door lock system
2. Remote keyless entry system
3. Power window system
4. Sunroof
5. Interior room lamp
6. Warning chime
7. Turn signal and hazard warning lamps
Configuration EKS00777
DESCRIPTION
U1000
CONFIGURATION has two functions as follows:
? READ CONFIGURATION is the function to confirm vehicle configuration of current BCM.
? WRITE CONFIGURATION is the function to write vehicle configuration on BCM.
CAUTION:
? When replacing BCM, you must perform WRITE CONFIGURATION with CONSULT-II.
? Complete the procedure of WRITE CONFIGURATION in order.
? If you set incorrect WRITE CONFIGURATION, incidents will occur.
? Configuration is different for each vehicle model. Confirm configuration of each vehicle model.
READ CONFIGURATION PROCEDURE
CAUTION:
If CONSULT-II is used with no connection of CONSULT-II CONVERTER, malfunctions might be
detected in self-diagnosis depending on control unit which carries out CAN communication.
This came right out of the 2004 titan manual don't think it's the answer you wanted to hear.
Mar 31, 2015 | 2004 Nissan Titan
My 2007 nissan titan engine shakes over 40 mph
i think that you need a drive shaft ujoint. titan engines are pretty bullet proof
Dec 23, 2010 | Nissan Titan Cars & Trucks
I have a 96 mazda b4000 and the check engine light is on how can you clear the code without using a scanner?
In obd-II vehicles, you can clear the code by having 40 or more cycles of start and run conditions followed by turning off the ignition completely without having an engine anomoly or issue.
It's easier to use the clear codes button on the obd-II scanner.
Nowadays, you can buy an OBD-II scanner for less than $100 at Walmart. I just got one.
Good luck on this.
Jun 27, 2010 | 1996 Nissan Pickup
I don't have driver for truscan titan yet
hi,
hope this can help you for your truscan titan drivers update at the link below.
http://support.vidar.com/default.htm
Nov 28, 2008 | VIDAR Systems VIDAR TruScan Titan II
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Lamp replacement
    Just replace the lamp! It's just a fluorescent light you can get anywhere. You don't need a new scanner, if I had to replace the scanner every time the lamp died I be in the poor house!
    Sep 17, 2007 | Agfa DuoScan Flatbed Scanner
    Titan II Monopod Quick release
    Go to Spartan Photo Center.Com and order the part. The size of the quick release is listed inside the receiving end of the mount
    May 10, 2007 | Quantaray Clamp Pod Flexible Monopod
    Kodak I-40 Scanner
    8 Face up light check failure is the only code listed, not "88" for this model.
    If code 8, the top lamp may well be occasionally flickering. Could be the Lamp or the Inverter (Ballast) check connections to lamp.
    Jan 12, 2007 | Kodak i40 Path-Through Scanner
    VIDAR Systems VIDAR TruScan Titan II Logo
    338 people viewed this question
    Top VIDAR Systems Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a VIDAR Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
