My Tassimo is leaking quite a bid from the bottom. It also makes a loud noise, no brew is coming out but the water is heating up... HELP
Check the peircing nozzle to make sure there are no small bits of foil from the disks in there. Descale the machine according to instructions in manual AND most useful for stopping the leaking was cleaning the little overflow nozzle located when you remove the cup stand/drip tray, followed by the splashback. The nozzle is located at the top of the little recess/indent. Clean with vinegar. Re assemble and test. Good luck.
Try http://www.theessentials.com/products/H42441.jsp they have a lot of parts for Tassimo. Jacco from Hawkesbury
When I use the new Starbuck disc, I only get 1.5 oz of coffee and the rest of the water goes into the overflow area.
My Braun Tassimo is leaking lots of water out of the bottom and also the auto light isn't coming on. Help!
My BraunTassimo has started leaking from the bottom of the machine at the rear end. This started after I descaled my machine.Is there anywhere that does repairs to Tassimo machines.
Machine leaks water on the bottom
Same thing!!!! Bottom leaking out of nowhere! I'm so mad they don't sell it anywhere!!!!
Same problem.... AND the coffe is not perking a full cup, what to do?
Water is not coming through just leaking out?
