Question about DCS Kitchen Ranges
The hinge on my dcs-rgs-305 oven door broke. The clip that holds the upper and lower arms of the hinge is gone somehow. CAn I order one? I can't seem to find it online anywhere.
    Problem Solver:
  • 7 Answers
May I ask you question about your DCS range?
Posted on Nov 06, 2009
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
Oven wont light ,igniter is O.K Burners on top work Seems like no gas comming into oven . What to do?
Ignitor is the most common problem, even when it appears to be glowing somewhat. If you've already replaced it, then it's the gas valve. Call for service!
Range repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Jan 25, 2011 | DCS RGS-305 Professional Gas Kitchen Range
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
My oven won't heat up and just smells like gas but my stove burners work
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening. If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Aug 17, 2009 | DCS RGS-305 Professional Gas Kitchen Range
DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Jul 25, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Jun 23, 2009 | DCS RGS-305 Professional Gas Kitchen Range
DCS 304 RGA, Igniters ok. 3.9amps, no oven or broiler. No part #
Did you ever find a solution to this problem? I think my RGA 304 has the same problem, and plan to go looking for that dual valve today... Peter
Feb 21, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Oven door hinges
It is tricky, it takes two people to hold door in place, put hindges into slots then fold downward towards the floor, the hinges will open all the way and it will snap back in.
Jan 11, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Can't get door back on
This technique is for a DCS range. On the hinge flanges their are two parts to each side. The lower flange has a little clip on it that attaches to the upper flange. To attach these bend these by laying the door down with the inside of the door up and using a rag or something to pad the palm of your hand, press the upper flange down till it meets the lower flange then hinge the clip up (that is on the lower one) and attach it on to the upper one. Do this on both sides then pick up door and slide the flanges into the slots on the range till they meet resistance. Bend the door down slightly, release the clips and close the door. If this doesn't work the first time, repeat process with different door angle. Be careful not to force anything, this is actually easier than it appears.
Nov 18, 2008 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
413 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
