Question about Kenmore Dryers
Electrical dryer gets too hot. Already cleaned vent completely, the vent from dryer to outside and the metal vent on the inside of the dryer itself.Thermostat reads 0 ohms.
  • Kenmore Master
  • 7,482 Answers
Your thermostat sounds like it needs to be replaced
Posted on Sep 25, 2009
The dryer is very hot to the touch after only a few minutes in the normal cycle.
inside dryer should be two screws in lint screen holder take out screws the hole piece comes out then you can get farther into the dryer to check for lint is the outside vent clear you could pull dryer vent off run without vent on back to tell if its a venting prom or in the dryer good luck
Apr 05, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My whirlpool LER8648L dryer makes a burning smell within 5 minutes of starting it was wondering what would cause that
Dryer Gets Too Hot
  • When you have a problem with your dryer getting too hot, there are many things that could be causing the problem. Check to see if there is lint inside of the vent hose or inside the outlet of the wall exhaust. A blocked vent will definitely cause a dryer to overheat because it does not permit the heat to exit the machine smoothly. Make sure that you are only using firm and rigid metal or bendable metal duct according the manufacturers instructions. Look for kinks within the vent hose. You should also check for any obstacles or obstructions inside the outer damper.
    Make it a practice to check the outside vent damper every other month or so. Check to see if you can feel a good flow of air being released out of the exhaust. If not, the blower may be in poor condition inside of the dryer. Some other possible reasons for overheating include, a bad operating thermostat, worn, drum seals or a shorted heater coil.
Apr 18, 2011 | Whirlpool LER8648L Electric Dryer
My hotpoint electric dryer gets very hot in the back in one spot has turned a brown spot in that area
Hi, the most likely cause is that you need to clean out the vent from the dryer to the outside of the house. First check behind the dryer and make sure that the vent is not crimped, crushed or pinched in any way. If it is then replace the ducting from the dryer to the well. If it is venting poorly then it will get pretty hot, the brown spot may be in relation to the ducting inside the dryer. Turn the dryer on and go outside to where the vent comes out, there a good amount of air coming out. If not, and if the vent goes a long distance through the wall you will need to have a vent cleaning service out. If you are getting strong air outside and the clothes are drying fast then you may have a bad thermostat that is letting the dryer get to hot, in which case you'll need to have a tech out to look at it. Good luck.
Sep 24, 2010 | Hotpoint NWXR473EV Dryer
I have a maytag performa electric dryer model #pye2300ayw, rev 10 -- sometimes I need to run the dryer 3-4 times to get a load dried. I checked the outside vent and there is alot of hot air coming out, the...
We had this same problem recently. Don't know if your problem is the same, but I am sure it could be.
While we did have hot air coming from the outside vent, it was still a restricted vent duct that was our problem. I went to Lowes and bought a dryer vent cleaning kit for about $40 (I figured I needed to do this anyway, as I'd been hearing about how many housefires are caused by the heat buildup from poorly breathing vent tubes/ducts), and cleaned the whole length of the duct (and replaced the plastic flexi-tube inside with a metal one).
I had thought I had good air-flow before doing this, but oh my gosh, what a difference this made! And I couldn't believe the pile of nasty, damp lint that came out!!
Anyway, our dryer immediately went from requiring 2-3 cycles to dry a load of clothes, to doing a great job the first time through! Perhaps the same solution would help you. I hope so!
May 29, 2010 | Maytag Dryers
How hot should a gas or electric dryer get, mine seems too hot
if the dryer is running hot it's because you haven't cleaned out the dryer?try running it with the vent line disconnected from the back of dryer,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to blow out the line,make sure the outside vent is clear first,no screens or cages in the way,if there is remove them all they do is catch lint,next unplug the dryer,clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac that blows on one end blow off the motor and blow all the lint from the back of dryer to the front so you don't have to remove the drum,do this once a year and you shouldn't have to many problems with the dryer
Mar 20, 2010 | Amana DLE330RAW Electric Dryer
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Clothes are not drying completely - even when I
before you call a repairman. check 2 things vent hose behind dyer for a kink or a restriction ( lint build up.) if your vent hose goes straight out make sure nothing is clogging the vent or the flapper outside, if vent goes up and through attic then outside vent system may need to be cleaned out. lowes sells a cleaner brush extension that you can buy and snake through your vent . this should be done yearly. we get service calls on this all the time and 9 out of 10 its not the dryer, but a ventilation problem, if the hot humid air cannot be released outside the dryer cannot dry your close. hope this helps. p.s their is proffesional companies that strickly do dryer vent cleaning if you would not rather do it your self.roughly 65-145 dollars depending were you live and who you use todo it.
Sep 17, 2009 | Dryers
I have to run the clothes through several cycles before they are dry
It sounds like you have a plugged dryer vent. Clean the vent from the dryer all the way to the outside of the house.
Aug 11, 2009 | Roper RES7646KQ Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
