Phillips 25x614-00a tv sits for awhile shows a brilliant picture but then starts getting louder until it reaches maximum. i try to turn it down but it just automatically turns back up. then it counts channels backward until it reaches the end and starts all back over. i turn it off but the button does not work. finally i am able to turn it off and it does with a bright light in the center as it goes off. it automatically turns back on as soon as i take my finger off the button. i have to unplug it before it will remain off.
  • 2 more comments
  • vernon johnson
    vernon johnson Sep 25, 2009
    do not have a remote everything is done manually. when i saw the light in the middle of the screen as it turned off i was thinking that i had some yoke problems .
  • vernon johnson
    that sounds very possible but when i unplug it and plug it back up it does not automatically come back on and when it does it does not automatically start doing the same thing until a few minutes and then it starts back up. i am not sure but it sounds like a component is at its breaking point and is getting hot and going into a different function. it seems to cool down but after it gets warm enough it starts to act back up again. i have known resistors to do this but which one could it be.
  • vernon johnson
    vernon johnson Sep 28, 2009
    i would like to get a second opinion on this problem please.
  • vernon johnson
    good rcommendation
  • 1,068 Answers
The main board is bad! had the same one a few month ago and i swapped it out and all was good! not that bad of a repair i think i got the board used for around 100 dollars and if you have basic repair skills you can do the work or get it fixed for under 200 at a repair shop. if you have any more question please ask i will do what i can to help! good luck.
please remember to accept and rate our chat!
Posted on Sep 28, 2009
  • 3,267 Answers
Most probably you are using a remote to operate the TV. The remote fas some key depressed constantly, hence the signal from the remote is malfunctioned. Get another remote, a universal one, and everything should work as earlier...................sodeep
Posted on Sep 25, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Sep 25, 2009
    If you do not use a remote then one of the buttons on the TV is remaining constantly in contact, not allowing changes, since that locked button i A cleaning with alcohol to remove carbon deposits may clear it, but ask the repairman to rectify it so as to get a warranty for at least 3 months......sodeep
  • Sudeep Chatterjee
    It starts after getting heated due to loose contact. That's why the disturbance comes after 10-20 minutes.........................................sodeep
Tries to turn over then wont let it sit awhile then it starts
It could be starter heatsoak (starter gets hot from engine heat and needs to cool down first).
You can fix it by putting heat wrap on the starter.
Feb 27, 2013 | 2003 Kia Sorento
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
2002 ford Taurus power streeing
You shouldn't need to replace 2 pumps,or even one. It shouldn't whine,where you hear it, driving.
I would change the steering rack,flush the cooler and pump. Still got a whine ,your getting bad rebuilt pumps
May 20, 2010 | 2002 Ford Taurus
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
Engine won't start until car sits for awhile after
replace the IAC or clean it. If it doesnt open when you try to start your engine it will not start, after it cools down it may work and let it start Idle Air Control Valve
Aug 17, 2009 | 2003 Ford Expedition
Looses video
There are so many thing that can cause this to happen. If you answer some questions we can narrow it down some. 1) when the picture goes black if you hit the menu button on the mitsubishi remote or on the front of the tv itself does the menu show up? 2) After it goes dark how do you get it back? do you turn it off and let it sit for awhile or can you turn it off and then right back on to get a picture? 3) what is the model number? this can be found on the back of the set. If you can answer these questions we can go forward.
Thanks!
Tim Nolan
Sep 11, 2008 | Mitsubishi WS-55807 TV
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Ps 3 no data
Try holding the power on button down until you hear a series of beeps, each one representing your ps3 switching video modes. try this until you get a picture on your screen, then you can use the options to set it to your tv's resolution. I've seen this same problem often from people holding the button when they turn it on :3.
Hope this helps.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
