Question about Dual Electronics XDM7510 CD Player
Xdm7510 will not accept any disc
Xdm7510 will not accept discs and i have already tried resetting the cd mechanism by holding eject for 3 seconds like it says in the manual
    Problem Solver:
  • 11 Answers
Try unhooking the battery for a couple minutes then hooking it back up
Posted on Sep 25, 2009
The Wii will not read my disc
Situation:
The Wii console will not accept game discs or the discs are ejecting immediately
What To Do:
Press the eject button on the front of the console. The console will not accept any discs if there is already a disc inserted, and it is common to forget that a disc was already inserted.
If the system still won't accept discs, or if the discs are immediately ejected, this indicates a problem with the mechanism that pulls the discs into the system and the Wii will need to be repaired. To begin the repair process, click here.
Nov 15, 2012 | Nintendo Wii Console
There is a cd stuck in my cd player, how can I get it out?
Try pressing the reset button. This sometimes helps eject the disc. If not i have found that by holding a second disc slightly above the stuck cd and very gently pressing down on the stuck cd, it can help eject the stuck disc. DO NOT INSERT A SECOND DISC. there is also a possibilty that the ejecting mechanisim is broken in that case taking in to the repair man would be the wise choice.
Respectfully
dreamsystems
Feb 04, 2011 | Pioneer DEH-P6900UB CD Player
We put a bluray disc in the PS3 and the disc is stuck and the console will not eject the disc and will not stay on. We have tried holding down the power button, holding down the eject button and nothing...
switch off power at the back. hold down eject button, keep holding, turn power button at the back to on. console fan will spin very fast ( at this time take your finger off the eject) then goes back to normal. try now to hold eject button for more than 9 sec; it will then eject your disc. if this dont help check this site: http://www.edepot.com/playstation3.html#PS3_Model_Differences
PS: most likely, you already have a problem with your Blu Ray laser (life span expired) or hopefully you will need to just re-allign your CD drive mechanics. dont open your console if you still covered with sony waranty. otherwise; give it a try; many youtube videos will show you how to do that.
Good luck
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
TEAC-P1260 - Initially Cd would play then eject randomly. Next would play only a few seconds then eject. Now has eaten a disc and will not eject. Any suggestions?
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricalshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT
Jun 08, 2009 | Teac CD-P1260 CD Player
I can't my Disc to eject from my Wii Console. Does anyone have a solution to this problem, other than taking it in for service?
Try all of these steps:
1. Turn the Wii off and on again after about 20 seconds. Press the eject button again. If no help:
2. Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. If no help: 3. Hold down the eject button for 5 to 10 seconds. Still not: 4. Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. if no help: 5. See if power light was coming on and do the AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for 5-10 seconds Finally: Call Nintendo 1-800-255-3700 and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Good Luck
Mar 03, 2009 | Nintendo Wii Console
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Radio works fine, put in a cd and it ejects it.
Unit will not accept
a disc
CD mechanism position out of alignment Press EJECT for 3 seconds to reset CD mechanism position
CD transit screws still in place Remove 2 transit screws located on top of the unit
You can down load the manual here at this site.
http://www.dualav.com/i/product/manual/xdm6825.pdf
Good Luck
Please rate at FixYa!
Dec 19, 2008 | Dual XDM6825 CD/MP3/WMA Player
Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
Nov 30, 2007 | JVC Arsenal KD-AR260
PS3 rejects disc's
simple , try cleaning your disc first, then put in PS3...
Aug 09, 2007 | Sony Playstation 3 (PS3) Console
Dual Electronics XDM7510 CD Player Logo
113 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
