Question about Whirlpool LEQ8858J Dryer
Clothes aren't getting dry very fast
Hi
I can't get my clothes to dry very fast. This just started happening yesterday.
The dryer heats up and all but it takes forever to get the clothes dry. I cleaned the lint trap, even washed it off with a hose outside. I checked the vent on the side of my house and everything there seems to be working properly.
Can you help me? Thank you!
  • TS66 Dec 22, 2007
    Thank you for your help. Very good ideas! I haven't figured out the problem but have only tried a few of your suggestions. I'll let you know when I do. Thanks again!
  • 833 Answers
First, check your circuit breakers, turn them off and on...there are two linked together labeled 40 amperes or more. Next guess will be the thermostat or the heating coils. Use a multimeter to check these parts. A diagram is usually attached to the back of the unit. Oh, is the drum turning? Are your clothes reasonably damp dry when you put them in? Is the vent hose kinked when the unit is in place?
Posted on Dec 18, 2007
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
My dryer will run for a couple of minutes then shut off we already replaced the heating element
If your dryer has electronic sensors like this:
They might have a coating builtup on them preventing them from feeling the wet clothes.As the wet clothes tumble in the dryer they rub up against these sensor strips. As long a wetness is there the capacitor is dicharged on the controls upstairs and it continues to dry them wet clothes. If junk gets on them sensors no wetness will e felt by them sensors. It is a simple as that. The dryer thinks the clothes is dry because no dampness is being detected so is shuts down thinking all is propah. Get some windex and scrub them sensors good so dampness can be sensed by the two sensors once more and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2011 | Dryers
I just got this HE dryer and the cloths aren't dry when the buzzer goes off. And the permanent press clothes are wrinkled... HELP! Plus it took almost 3 hours to dry sheets
It could have a faulty thermostat which shuts down to fast in drying mode, be sure and check that the vent is clear and not obstructed at all, thats the only way moisture has to leave the machine and dry the clothes
Jun 17, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
183 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
