Question about Dryers
The drum rotates. and the heating element heats up and smells . fan is working intermittently. my guess is, its the fan.
  • raindog24 Sep 25, 2009
    we took it apart. nothings loose. the vents are clean. the fan works intermittently. it has squeeked for months. put some more grease on the back end and the squeeking is better but still there. thats not the problem though. its the fan, just goes on and off.
  • Dryers Master
  • 7,482 Answers
That would be my guess also...but also make sure your vent is clean
Posted on Sep 25, 2009
    President:
  • 1,922 Answers
Is it noisy like the fan is loose on the shaft" most fans are direct off motor
  • daniel  hendrickson
    daniel hendrickson Sep 25, 2009
    have you isolated the fan and operated it w/o any other item on unit operating i.e. the heating element,another thing check your neutral connection from the input and see if theres any intermittant connections, this goes for all connections as they are under stress of hi humidity and heat acd cool cycles and can become brittle with time
Smells like electrical inside the drum
Do you have heat in the Dryer still? If not and you have the smell the heating element probably blew a fuses due to lint build up. or the heating element itself is bad.
Nov 13, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Where is thermostat located on ge dryer,starts hot then it gets cool
Dryer possibly overheating due to plugged vent. They will go into a safe mode and shutdown the heater if not enough airflow. Results in starting hot but ending with a cold load of clothes! Check the belt to ensure the dryer fan is working and that the drum is properly rotating. If OK and the vent is clear then check the thermostat. Depengin on the type (Gas vs electric) there are a number of limit thermostats as well as a main thermostat. Likely you have a a limit switch kicking in to shut off the heater. Normally from lack of airflow (plugged vent, fan broken, etc...) Once unit cools down will start back up but shut down again once the heater comes on. Also check to see if the heating element is shorted to the side of the metal case. Will heat up and be intermittent.
Jun 10, 2014 | Dryers
Dryer makes clicking noise but won t start
The heating element is working or the belt is slipping.
the drum does NOT turn?
See manual. un plug and pop the front off to see if the belt is attached.. Try to rotate the drum by hand.
Aug 26, 2013 | LG Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
HEAT PUMP
It is not normal to have a loud buzz associated with the electric heat. Try turning the heat off and running the fan only to see if the buzz continues. The buzz could be coming from any number of sources including an electrical component, the blower wheel, a loose fastener...etc.
The temporary smoke and smell could have been the dust burning off the element if the elements have not been used in a long time. However, if the elements have been running, it could be something got loose in your system and stuck between the blower and the heating elements.....for example, the wiring diagram could have come loose and worked it's way through the wheel. I've also seen owner's manuals left in the air handler that eventually got stuck in the blower. This should be inspected to ensure there is not a fire hazard.
I hope this helps and good luck. :-)
Feb 24, 2010 | Friedrich Heating & Cooling
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
The heating element( I'm guessing) inside the dryer, behind the panel with the 3 screws got really red hot and smelled of smoke. I have a gauge thing from the hardware store to check to see if the heating...
last thing u wanted to do was remove the three middle srew they hold the drum .
u are going to need someone else to help,first try to reinstall the srews .
after reinstalling
top left back there is a thermal fuse this fuse goes when the element goes element about $95.00
fuse 13.00
under neath the panel next to timer 1 black screw on other side 1 more screw remove
remove casing with both timers.more screws
un clip all wire harness
all screws on top off
look at belt remember how it came off
now remove front panel
remove belt
push up drum hard
remove drum
now u can get too the heater
best of luck al
May 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to www.repairclinic.com and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
Intermittant buzzing vibration like sound when drying.
Check your lint filter may have lint filter alert.
Apr 22, 2009 | Roper REX3614KW Electric Dryer
Dryer heater not working
If it is an electric heater that means that either the heating element, or the thermistor , or the cirrcuit breaker connecting the element must be replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 12, 2008 | Hoover Washing Machines
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
