Question about Sharp AR-156 Copier
Sharp AR-156 Developer light stays on.but the
Changed the developer on my Sharp AR-156 but the light still shows it needs to be changed. How do you reset the developer light??
  • ltcol54 Sep 28, 2009
    There is a Developed light on the lower left side of the indication panel and also a maintenance light. When these came on I changed the developer as required, but the same 2 lights remain on at present. The toner light is off but it still shows maintenance required to change the developer.
  • Everett Lin May 11, 2010
    Hello sir; There have not indicator for developer on this machine, could you descript what's light look like?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
In service mode
Posted on Sep 28, 2009
    New Friend:
I really need a reset code to clear AR SHARP 5320E which display developer light and toner light together
Posted on Oct 24, 2013
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Developer signal
On a Sharp AR-201, the developer light comes on when 50,000 pages have been made since the technician (or factory,) last changed the developer substance and reset the counter. A tech should come out with a Preventative Maintenance kit because training is needed to remove the developer substance safely as well as to clean the optics, interior and inspect the fixing unit, drum and cleaning blade and vacuum out the copier. You should call for service and tell them the developer light is on so they know to bring a kit. And yes... I am factory trained on this model. Retired now.
Nov 24, 2012 | Sharp AR 201 Copier
Code CH s.v.p.
i really need a code to reset AR-sharp 5320E which display developer light with toner light together at the same time
Jan 30, 2011 | Sharp AR-156 Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
My machine is sharp AR-163 and is showing developer sign and ch sign
developer probably needs changed. CH means you have a cover open
Dec 08, 2009 | Sharp AR 163 Copier
How do I change the developer on a Sharp AR-156?
The developer sits in a small, black casing that houses the toner bottle. When you pull out the toner, look for a small, blue or green screw that holds the developer box in.
Once you pull the developer out, you'll notice three screws on the outer casing (two on top as you look down on the unit, plus one looking down into the opening where the toner bottle sits). Removed these screws and set them aside. You should now be able to pull the cover off the unit and expose the developer assembly.
Dump out the old toner in a plastic bag. Be careful, as it can spill out quite easily and it's a pain to clean up out of carpets. You'll want to invert the developer unit and use the plastic gear on the backside of the unit to spin the magnetic rod until all of the developer has been removed (be careful not to scratch the surface of this rod, as it's what holds the developer in place during copy processes).
Place the new developer into the open auger area of the unit. Put the cover back on and install the three screws you removed earlier. Place the developer assembly back into the body of the copier and screw the blue or green retaining screw back into place. Now you can re-install the toner bottle and start the copier back up.
Sep 10, 2009 | Sharp AR-156 Copier
How do I change the developer for a Sharp AR-156?
It's part of a kit. You'll need to consult their support site or a tech to get the part number and pricing. It's all disposable these days...
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-156 Copier Logo
321 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
