Question about Poulan Garden
Saw will start an run short period and stop.Only start when adding gas directly into carberator. This is a Poulan 16 chain saw.
    Problem Solver:
  • 15 Answers
If it is a old saw it sounds like your engine seals are failing. when a engine seal fails it allows air in past the crank upsetting your fuel mixture You could try to richin the fuel mixture by turning the screw marked H anticlockwise a quarter at a time untill it runs Ps to set (h) screw to factory, screw it in til it stops then unscrew it 1 & 1/2 turns
Posted on Sep 25, 2009
Chain saw is not oiling the chain
adjust oiler screw on bottom of saw--clean out area behind chain cover
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Apr 26, 2014 | Poulan/Weed Eater Poulan Pro 35 cc 16" Gas...
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
I can start my Poulan 2000 16" chain saw but it
If the saw is brand new, take it into a service dealer for a carb adjustment (covered under the warranty). This sounds like it is your issue and unfortunately, you cannot correct it yourself because it requires a special tool.
As for you manual, it is located at the link below http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137248.pdf
Jun 25, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Gas ratio
Most saws built within the last 30 years or so can be run with 40:1 using modern synthetic saw oils. A number of late model units run 50:1. Make sure to premix the fuel and oil before adding to the saw. Hope this helps!
May 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 14" chain saw will not start
Usually, the fuel filter gets gummed-up from leaving it in any kind of fuel for long periods of time. Fish it out of the tank and either clean it in spray-carburetor-cleaner or replace it. Check the condition of the fuel lines while you are at it. Proper storage is to drain the tank and run the engine until it stops. If still won't run, the carburetor internals may need cleaning and re-kitting. Make sure the spark plug is firing correctly. Hope this helps!
Apr 19, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Hi...I have a Poulan chain saw 2000. I can not
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1b4ef1f00fa5e65888256bfa0019583f?OpenDocument
Did you replace the hoses? It only needs a pin hole. This is older than dirt! I can say that, I have a XXV. There should be an impulse line from the crankcase to the carb somewhere, it may be bad. Crank seals may be leaking. Maybe time to spring for a pressure diagnostic by your friendly local Stihl shop. HTH
Lou
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
I just bought a Poulan 16'' chain saw with quick adjust chain tensioning. The chain seems to loosen after a short time of use and the chain comes off. Quite disturbing.
1. It is common for a new chain to stretch. that is probably what occurred
2. I'd hold the tip of the bar 2-3" above a stump or even a news paper, rev it up for a few seconds and look for a line of bar oil. If none is visible your bar oil reservoir is empty or saw isn't oiling. If you added oil and it's not oiling return it to where you purchased it.
HTH
Lou
Sep 08, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
185 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
