Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 665.16039403 leaks water when filling
I removed the front access panel and can see a steady stream of water coming down from the dishwasher when the machine is filling; towards the back of the unit, but I can't see exactly from where. Water begins flowing as soon as fill cycle starts. No problems during the drain cycle, and definitely not a door gasket problem. Unit is 3 years old. Thoughts?
  • 999 Answers
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Posted on Sep 25, 2009
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
Step 2:
Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
Step 3:
Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
Step 2:
Open the door completely and remove the bottom dish rack.
Step 3:
Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
Step 4:
Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
Step 5:
Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
Step 6:
Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step 3:
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step 4:
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step 5:
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Apr 06, 2008 | Dishwashers
I have a kenwood KDW12ST3A dishwasher. i have lost the manual and the dishwasher is displaying code E4.What does this mean ??
HERE IS A LEAK AND IT IS BUILDING UP IN THE BOTTOM DRIP TRAY!. It is filling up the drip tray and tripping the micro switch. Remove the lid(2 screws at rear),givng access to screws on top of right side panel,remove right side panel, you will have to remove plastic cover on bottom front first to give access to screws on side panel. This gives access to the hoses and such, where the leak is most likely coming from. I would buy some inch and a half to 2 inch hose clips first, as the clips on the machine are not really reusable.The machine will have to be put on its left side, you may have to remove the bottom drip tray also, this holds the micro switch and the polystyrene float. You may have to run the machine to see where the leak is coming from, It is time consuming, but very "doable", remember electricity and water do not mix,unplug and make sure everything is dry, particularly yourself!.
Apr 26, 2011 | Dishwashers
Water leaking at the bottom of the door
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Nov 24, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My Hot Point Dishwasher is leaking water. It was
Hi
Check for any kind of leaks around lower spray arm or soap door. Replace the arm if any cracks are found. Also make sure that door latches firmly, and the gasket is not cut.
The leak can also happen due to a broken fill valve. To check, take off the access panel from the front of the dishwasher so you can reach the fill valve attached to the metal bracket. Use a multimeter to check the continuity across the two black terminals at the top of the fill valve. If it reads 120 V, replace the fill valve. Make sure the thin filter screen between the bracket and fill valve is not blocked by debris.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Water dispenser in door front is leaking.
The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
Nov 04, 2009 | Kenmore Refrigerators
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Leak from dishwasher fill funnel
    Hi . the air gap is required by law, to have it there.to stop water in the tub, to end up in your water system, which would never happen. try setting the pressure down, and use the dishwasher. it should work fine . turn down taps ,till it stops leaking . should be ok
    Oct 06, 2008 | Kenmore 15129 Built-in Dishwasher
    My kenmore built in dishwasher is leaking out the front
    change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
    Feb 02, 2008 | Dishwashers
    Kenmore 24 in. 16032 Built-in Dishwasher Logo
    162 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
