Question about Zebra 105Se Thermal Printer
Instead of printing consistently, the ribbon backs up. How do I get it to stop backfeeding
    Problem Solver:
  • 15 Answers
Sounds like the either the ribbon supply or ribbon take-up pressure needs to be adjusted.
Supply Spindle: a pair of set screws near the outermost point on the spindle locks the adjustment in place. Loosen the set screws, then move the center pin in or out to change the spindle pressure. Tighten the set screws then test print
Takeup Spindle: a pair of set screws locks the large adjustment nut in place. Loosen the set screws, then tighten or loosen the large nut, tighten the set screws and test print.
Posted on Dec 15, 2009
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
My printer always start printing short so that the lables end up on two pieces instead of one
We must establish whether the problem is a moving label or just that the labels are not aligned properly. Is hte printing split across the two labels consistant regardless of hte number of labels printed? If so, then the lables are not aligned properly. The user manual has the procedure for aligning these. This is part of the setup procedure.
If hte first line of the labels changes position on subsequent printings, then either the label size is not defined properly or the format being used is not correct. I don't have the manual handy at the moment so I can't give you the particulars, but if you could update this and tell me which of the 2 conditions you are experiencing, I will look up the specifics in the morning.
Thanks,
Dan
Dec 09, 2010 | Zebra Z4M Printer
HI,when I print , the printer do some label , after go in pause mode automatically message=" = continue = reprint" but after 1o label , the printer give a second error "out of ribbon" .Can you help me...
Hello
After many efforts I have found that in the new PX6i models, the "transfer ribbon mechanism" (the wheel that is responsible for making the ribbon roll) appears to be defective. What happens is that when rolling back in order to keep the ribbon stretched, instead of stopping at the fixed point, it continues to roll back a bit. After a few prints, this causes an "out of ribbon" error.
The solution: replace this part with a VALID part (a new one).
Pavel
Feb 08, 2010 | Intermec EasyCoder PX6i Thermal Label...
MY WORDSMITH 250 PRINTS II INSTEAD OF LETTERS WHAT CODES DO I NEED TO USE TO CLEAR THIS
the markes you see is the print hammer hitting the ribbon & paper. remove the ribbon & print wheel. look close at the print wheel when out of the machine if there are any spaces betwen the spokes a letter has broken off and you need a new print wheel, If just bent slowly strten them out. reinstall wheel & ribbon try it.
C.W.H.
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
GenicomTally T6215 line printer not printing on edges
If your still having problems? 1st make sure the gap is not to tight(cause the to ribbon to drag up with paper). 2nd While printing in test mode, carefully lift up or push down on the ribbon where it comes out or where it goes back in the catridge. After doing the 2nd you should see the exact same thing as will stop printing on right and left edges. Remove the ribbon, their are 2 philip screw on the left and right side of the ribbon deck, loosen them(they will not come all the way out, held on by clips) lift the rbbon deck up and reseat it... tighten the screws back down. last you may have some bad ribbons...
Jan 14, 2009 | Tally Line Matrix T6215 Printer
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
Problem while printing black on the black side
check the printer driver and see if YMCKK is selected in the driver.
Aug 07, 2008 | Fargo Pro L ID Thermal Printer
Dual sided printing
First, go to the print drivers and make sure that you have a dual sided ribbon selected (YMCKOK). Make sure you have the print driver set to print two sided cards.
If you need further assistance, Evolis technical assistance is available on our blog at www.safecardid.com/blog.
Jul 07, 2008 | Evolis Dualys Thermal Card Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105Se Thermal Printer Logo
343 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
