Question about Hotpoint RLA30 Compact Refrigerator
It has started to leak water mainly during the day but not overnight
At the back of the fridge is a little drainage system. I tend to clean the hole out with a cotton bud and some bleach...it works if u keep on top of it...
Posted on Nov 10, 2009
Why is my refrigerator leaking from the bottom i have model GI6FARXXF05
We have the same unit and was having the same issue. The overflow line is either frozen or blocked. We had to empty the fridge/freezer and unplug overnight to let the line thaw. We did and turned it back on the next day (after cleaning up the water that had collected in the freezer drawer during the night) and have not had a leak issue since.
May 02, 2014 | Whirlpool Refrigerators
Start rains
something is leaking when it rains. Keep using the blanket
Mar 10, 2014 | Ford Fairmont Cars & Trucks
I have a RS643V are the contents in the fridge
The 643V has an issue that it can freeze the water in the line during winter.
You must switch the fridge off until the water starts to run again. Then set the temperature of the fridge up as high as possible in winter. Draw 1 litre of water at least twice a day during winter.
This fixed my problem.
You can set the tempertaure back down in the fridge during summer without a problem.
Jul 06, 2010 | Westinghouse Refrigerators
My 2000 Catera drains the battery overnight and requires charging to start the next day. What is going on?
I had the same problem, it ended up being that the Body Control Module was water damaged due to a leak in the drainage hoses from the sunroof.
Jun 28, 2010 | 2000 Cadillac Catera
I was looking at a 5 year old whirlpool full sized thin twin stack washer/dryer and the complaint was that it was leaking intermittenly. I could never get it to leak while I was there until yesterday when...
well i personally have not heard of this before.did the speed of the agitation change with the level of the water.it makes sense because the blades are larger on the bottom of the agitator.with clothes in the washer this should cut down on the water splashing.
Jan 24, 2010 | Washing Machines
Leak during rinse and final spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 20, 2009 | Washing Machines
Fisher & paykel ilw16us leaks water when filling
During fill only
All the time
May 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Leaks water out overnight
I bet it leaks from the back, right? If it does, it has the same problem as my dad's.
You have a leak in the back of the holding tank. Fill it up, turn it around, without plugging it in, and watch for the water leak. If it's in a spot that you can see, then use some caulking to seal the leak. That should work. If not, it is leaking out from inside the plastic holding tank. Not much you can do but buy a new one.
Mar 01, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Water comes out of soap dispenser
http://www.applianceaid.com/neptune.html click this link and click the required option in the link Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
Jan 27, 2009 | Maytag MAH6700A Neptune High Efficiency...
My Ge washing machine is leaking from the Bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
Hotpoint RLA30 Compact Refrigerator Logo
239 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
