Question about Toshiba 36A40 36" TV
Toshiba 32HF72 TV just turned off while wathcing it. Now the power button blinks but won't come back on. Any ideas. Thanks for your help
  • 2 more comments
  • nmduck Oct 16, 2008
    Is it worth fixing?
  • Anonymous Oct 22, 2008
    I have a Toshiba 36" 36a60, was working fine now it won't turn on the power light just blinks when I press the power button.
  • n2nscr70 Dec 30, 2008
  • Anonymous Feb 07, 2009
    no tv picture. power button blinks
  • 129 Answers
Good day.
Power indicator blinking means that there is a missing link in the power signal flow of your unit. Perhaps one of the circuitry bug down. It could be anywhere in the circuit. Have a technician check your unit.
chris
Posted on Mar 23, 2008
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
I have a toshiba 32c120u and the remote is gone and i cannot operate any functions on the t.v. it just says not available at the bottom whatever button I press
Set should at least power up and have some functions even if no remote---tried to unplug it for a while so when powered back it can try to reboot? Disconnect any box if being used also to see what happens.
May 30, 2012 | Toshiba 32HF72 32" TV
The power indicator light is blinking. Tv will not turn on... Toshiba model 32HF72 I have tried to reset...wont reset
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore.....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact toshiba service centre.........
Apr 17, 2011 | Toshiba 32HF72 32" TV
I have a Toshiba TP61F80, i have had the tv for little less than a year. It is a GREAT tv I love it. My tv is plugged into my home stereo so when i power that on tv turns on as well. I pushed the power...
Try unplugging the unit for 10 minutes, then plug back in and try it. If the unit just has a fault this will reset it and it should work. If it does not solve your problem I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which explains the troubleshooting process and should help you isolate the problem. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 21, 2010 | Toshiba TP61F80 61 in. Rear Projection...
The red light on my toshiba 32hf72 tv is flashing and the tv will not turn on
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Toshiba 32HF72 32" TV
Toshiba CF27H50 cannot switch from TV to Cable
Have you tried pressing the cable or TV buttons on the remote?
I hope this solution is helpful.
Feb 13, 2009 | Toshiba CF27H50 TV
Toshiba 32HF72 32" tv
While on ebay and looking up my set i seen a pcb for a Toshiba 32" but can't remember the exact set number, i think it had HF in it, but not sure...it was from a dealer cleaning out old stock, he said $165 retail and was selling it for $105. Maybe just keep checking there, he may repost the sale again.
Nov 09, 2007 | Toshiba CZ32V51 32" TV
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Toshiba 36A40 36" TV Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
