Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS to DVD
All I need to do is transfer non protected VHS tapes to DVD-R. No menus or anything fancy, just a decent duplication. Would any of you know the simplest way to do that ? Can it be done without a TV ?
Thank you very much.
    Problem Solver:
  • 11 Answers
You would need a tv tuner on your pc's graphics card, then you could hook up the vcr with an adapter and record the vhs to your pc, then you would have to burn that to dvd. I don't think you can go directly from vhs to dvd, without an actual device (where there are those that do that.) ADS Tech's $100 DVD Xpress DX2. The DX2 has a video converter that can accept composite or S-Video signals. It converts these to digital format and sends them to a PC via a USB connection. It comes with Ulead VideoStudio 9 SE DVD software for editing the video.
Posted on Dec 16, 2007
Will this model record from the vhs tape to the dvd?
You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
Nov 19, 2015 | Televison & Video
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
Nov 13, 2015 | Zenith XBR716
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
I want to transfer from vhs to dvd. Video tape is protected.
You can copy VHS tapes that cannot be done on standard equipment. You can buy EZGRABBER to down load VHS tapes to your hard drive, then use a program likePower Produucer to go from your hard drive to a recordable DVD unit if you have one installed in your computer
Apr 21, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
VHS backups on DVD
Your VCR will NOT copy any commercialy published tapes to DVD disks. There is a protection built in to every sync line of the video on the VCR tapes. This is known as MacroVision protection.
The machine that you bought has been designed to block anything with MacroVision, and anything with any other industry standard copy protections. The codes for this are permanently burned in to the main uPC of the machine.
The publishers of the tapes do not know who is copying for what purpose, and how many are being copied. Under copyright laws they have the right to to take whatever action necessary to protect all their publications.
Jerry G.
Jun 11, 2008 | Televison & Video
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
