Question about Craftsman Garden
I wish to know if I can purchase new blades for my hedge trimmer model number 900.799740 . Can I replace blade with 22 inch or longer size? Can original blade be sharpened? What new model is compatable?
  • 437 Answers
Go to www.partsdirect.com, this is sears website for parts. You should be able to find the part number for a new blade.
If the blade has bolts and nuts holding the blade together it can be sharpened. If it is riveted together, it can be but it is more work than what it is worth.
Posted on Sep 25, 2009
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Do I need toil this Remington 22in electric hedge trimmer?
It's always a good idea to oil the blade of a hedge trimmer with WD40 or similar otherwise the sap from branches will eventually build up a coating on the blades and increase friction.
May 11, 2011 | Remington 22-Inch Dual Action Titanium...
My 22inch Hedge Hog trimmer (model cht500) 14.4v blades are moving very slowly. Purchased another charger but that did not help the situation. Any thoughts -battery need replacing?
possably the cells in the batt r warn out, take the battery appart nd charge nd c if they r holding charge, if they are you can buy them from a shop on ebay which is really cheap, there probably 1.2 volts, 1400 mha which is tiny. ive got 6800 mha batts in my hedge hog
Mar 12, 2011 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Jul 21, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Feb 12, 2010 | Garden
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Garden Logo
124 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
