Question about Kitchen Ranges
Our Jenn air svd48600w has had the clock control panel replaced 3 times. The replacement lasts about 6 months and then the alarm starts beeping again. We have to unplug the control panel to silence the alarm and then the oven and clock do not work.
    President:
  • 1,723 Answers
I would recommend putting 'surge protection' on the house breaker panel. I would suspect that you are getting power bumps that kill the EOC. Do you have power outage and lightning?
metertreater.com has some good stuff. Have an electricaina install it at the meter. Or you can put it right in the main panel yourself if you know how.
Posted on Sep 26, 2009
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Jenn-Air svd48600w chiming and displays f7 on control panel and the buttons on the panel no longer work. The only way to make it stop is to flip the breaker, then it starts again after a few minutes. For...
http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=4090068
whats happening her is that you are getting a stuck button error
it keeps happening because when you reset, the stuck button is still stuck and it gives you the error again
Maytag suggest replacing bothe the touch pad and the erc, but I have onle had to do both twice in the last 15 years,,,,
both had water damge
since you dont mention water , I would be willing to guess the part at the end of that link should be the only one you need to replace
Oct 17, 2009 | Jenn-Air SVE47100 Slide-In Electric...
F 1 code after using Jenn-Aire electric oven
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem.This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Sep 21, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
232 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
