SAY PAGE TO COMPLEX WHEN I SEND A PAGE TO PRINT. IT JUST STARTED TO DO IT. THEN IT FREEZES UP I HAVE TO TO OFF AND ON
  • 624 Answers
SOURCE: Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 05, 2007
  • 883 Answers
SOURCE: Page Too Complex Error
try sending a page with extremely little to print, such as one word...any change...I am suspecting printer memory overflow
Posted on May 30, 2007
Bubbabear64
  • 2794 Answers
SOURCE: HP 2840 Page to Complex (Ethernet Printing)
Try using a PCL driver
At this HP link
This link above is for windows XP
Posted on Jul 15, 2008
SOURCE: Page too Complex
Sometimes you may come across this type of a problem when the device is not able to print the current page because of its complex nature.
The speed of the USB on the product needs to be lowered. This can be done by turning off the “High Speed USB”.
Given below are instructions to follow from the Secondary Service menu:
Press MENU button to access Secondary Service Menu.
Press the #2 button and use the < arrow to navigate to the High Speed USB selection. Press Enter > OFF > Enter.
Press the Cancel button twice to exit the Secondary Service Menu.
Posted on Jul 25, 2008
SOURCE: "Page Too Complex" message
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Posted on Feb 15, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    I'm trying to print its says page too complex
    A solution might be the proposed in this webpage:
    http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-Drivers/page-too-complex/td-p/88560
    Also, might be a problem with your driver, Download from HP website the latest driver available for your pronter model and intall it.
    At this webpage you have the procedure for some other model but it shold be basically the same applied to your model.
    HP Color LaserJet 2600n Page Too Complex Errors along with Blank Pages
    page too complex
    If still can't print, do a Google search for "PAGE TOO COMPLEX" and youll find more comments about issue.
    Oct 23, 2015 | HP Color LaserJet 2840 All-in-One -...
    Lexmark E250dn Printer running slow almost half speed?
    Check the paper type you have set to print to. I the print thinks it is printing labels or envelopes it will run slower to ensure that it can bond the toner to the page. Also check how complex a print job you are sending. These units do not come stock with that much memory and a complex job (like a detailed photo) will slow them down.
    Jun 10, 2015 | Lexmark Office Equipment & Supplies
    Good day i'm having a freezing problem with my printer if i send 10-100 prints it processes then prints half the job and then freezes with processing written on the screen please help!
    Dear Sinclair
    The freezing occurs due to two things.
    1- when you command print file size is more than the buffer RAM of the printer. ( it will solved choosing page no. selection to print). If there is option to increase the RAM of printer, may be up graded.
    2- Fixing temp. when exceeds predetermined temp. it takes a short time may be neglected.
    Thanks.
    Mar 18, 2015 | HP LaserJet 5200 Printer
    HP laserjet 5200 printer taking too much time to print a page..
    HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
    Try to send a test or a text page to calculate the difference.
    Also bare in mind that first page takes longer to print due to printer heat-up procedure.
    Nov 09, 2010 | HP LaserJet 5200 Printer
    I have a HP LasterJet P2015. I am trying to print multiple page PDF file documents and after one page has printed, the triangle and "!" light flashes and a print out says insufficient memory. How do I...
    Open Printer options and reduce the print quality. It is probably 1200dpi. Make it 600 and try the print again.
    You may also add more printer memory to print complex documents on highest resolution possible.
    Aug 06, 2010 | HP LaserJet P2015 Printer
    Every page covered in magenta and black won't print across the page
    This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
    Sep 04, 2008 | HP Color LaserJet 2600n Printer
    Page too Complex
    Jul 10, 2008 | HP LaserJet 2840 All-In-One Printer
    May 30, 2007 | HP LaserJet 2550Ln Printer
    19 people viewed this question
    jasbo
    jasbo
