Question about Canon ZR800 Mini DV Digital Camcorder
No Sound? I did a test recording and am able to playback and view it on the LCD. The sound is on and the volume is up, but the playback will not play with sound. Am I doing something else wrong? How do I know the sound recorded? Thanks!
  • sallya Mar 31, 2008
    I have had sound on this camera but suddenly the sound has stopped working when I record.  I can still hear sound through the camera playback on earlier recordings but recently there has been no sound.  Help.
  • Canon Master
  • 2,794 Answers
Make sure the volume is up by press the function controls on the lcd display. Was there anything plugged into the mic input of the camera?
Posted on Jun 09, 2008
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
My microphone records the sounds on my computer and plays them directly back through the speakers. How can I eliminate the microphone playback and have someone else hear me on something such as skype?
double click on the volume on the taskbar (System Tray - Next to clock) and Controls for Playback will open. If you can't see Microphone Volume here, click Options- Properties - and in Playback Volume list - Select Microphone by ticking against it and press OK. You will see the Microphone Volume on screen. Just tick inside the mute box of Microphone. Now the audio from Microphone will not play but you can still record it.
Nov 16, 2010 | Sony VAIO VGN-AR630E Notebook
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
Speakers
I suggest that you check and ensure that the correct playback and recording device is selected in the sound properties of your system. Please refer to the steps below as a reference.
1. Click on Start > Control Panel.
2. In Control Panel click on classic view, located at the side bar.
3. Next double click on ‘Sound’ and go to ‘Playback’ tab.
4. Please ensure that under ‘Playback’ tab; the headset is selected as default device.
5. Next go to ‘Recording’ tab and ensure that the microphone of the headset is selected as default device.
6. Now, try to take a test recording using Sound recorder.
7. Click on Start > All Programs > Accessories > Sound recorder
8. Take a test recording with Sound recording using the microphone of the webcam. Then playback the recording and check whether it was recorded clearly.
Jan 11, 2009 | Dell Inspiron B130 Notebook
No sound in edit view
Well, the settings in edit view and mutitrack view are not, unfortunately, the same... you can set them the same, but it's not that way by default.
I haven't used 1.5 in a while, but my initial guess is that one of these are true:
  1. You've muted audio play-back on the edit view
  2. You've disabled monitoring on edit view
  3. The playback source in edit view is set to the wrong hardware.
  4. I believe there was a playback volume controle even in 1.5.  If so, you could have actually turned the volume all the way down for playback..
If I get a chance later this afternoon, I might try reinstalling 1.5 and seeing if I can get figure it out on that version.
Post back with your results so far.
Also, it'll be helpful to know what version of Windows you're using.  In Windows Vista, there's a volume mixer where you can control the volume for any open applications as well as Windows sounds - different than the typical mixer setup in XP and prior.
Jan 06, 2009 | Adobe Audition 1.5
Audio in playback mode doesn't work
Hi There, Try this: Connect you camcorder to your tv set via a/v input cable. Put camera in cam mode so you can see the picture on the tv. Turn up the volume on tv and if it squeels, the mic on the cam is ok. Record something and then play it back on the tv, if its ok, then all your audio is functioning. This means that the SPEAKER on your camera is defective.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Video was recorded with volume but no sound on playback
Be sure that the camera is able to record with sound. When you mean no sound during playback are you talking about playback thru the camera or playback on computer after you download it. Be sure that your camera has a speaker on it to play sound back or that the volume playback is turned up. Also, to help with your situation a little better when asking for help list the model number and manufacture when ever possible. It will help with lengthy feedbacks.
Jun 09, 2008 | Fuji Cameras
No audio during playback
On my handycam you have to hit the Volume + button while playing back. Everytime you playback it starts volume at zero and you have to volume up to hear anytime you playback.
Dec 24, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
172 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
