Question about Compaq 204015-001 - UPS T700 - UPS - 700 VA - UPS battery (204015001UPS) UPS System
I Have UPS 700-6000VA. It keeps changing on battery mode while on power, them reads error message bypass not available. Any help?
    Novelist:
  • 169 Answers
Bypass not available is a common alarm.
This is because the input and ouput parameters
volts and frequency do not match, suggest checking these with meter or using ups sw and comp.
Bypass will not function if either v or f is incorrect, check manual for specs.
Post more info about batt on load with mains conected please, as this could mean major fault such as rectifier failure or micro malfunction
Hope this helps, thanks for asking FixYa
Posted on Sep 27, 2009
Powerware 9390 UPS error configuration and circuit breaker battery check
9390 Requires a UVR type battery breaker. Unfortunately a configuration error will require a service visit from a technician. The proprietary service software will have to be used to reset this.
Apr 14, 2015 | Powerware 9390 UPS System
UPS Bypass mode failure
it looks like you have a faulty static switch
Apr 11, 2014 | Eaton Powerware 9355 UPS System
I have an Eaton 9355 20kva system. Theres an alarm #188 Bypass Failure and notice#105 Bypass Not available. The batteries are also not charging or the battery current is reading 0 amps. When the power goes...
Bypass failure is the same as your input unless you have a dual input. You lost power and the UPS did not hold the load because the batteries are bad. Replace the batteries and you will be ok.
Feb 18, 2013 | Eaton Powerware 9355 UPS System
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
Model 9155 display says: "UPS
bypass is not available because your input is going in one phase rotation and the bypass is going another. Both input and bypass needs to be a clockwise rotation. A cheap phase rotation meter will fix this. Call me at Gruber Power Services for free tech. support 800-658-5883 x256 ask for Eric
Aug 23, 2011 | Eaton Powerware 9155 UPS UPS System
Symmetra LX "Intelligence Module Fault". Does
First calculate the total load of the UPS and then calculate the total load. One of the Intel Module is Primary and one is Secondary. I can't remember exactly which one is primary. Q1. There will be a LED on the INTELI MODULE flashing RED. That identifies the bad MODULE. Q2. You can remove the MODULE, but I recommend you place the UPS in Static Bypass first through the Display Menu. Also make sure the UPS is in NORMAL MODE or already in STATIC BYPASS, the LED's on the Display should indicate what mode its in. Q3. You can remove the display from the Inteli Module with out harming the load. You just can't do anything with the UPS, as to tell it to Go to Bypass (Static Bypass) or get out of Bypass, check voltages, etc. So order the part first by getting part number on the sticker off the Module, then schedule your shutdown and perform the you maintenance after hours this way you don't affect anything during business. Also don't do the repair on a Friday due to the fact its weekend and APC/Third party UPS companies will charge you a lot to come out in the weekends. FIRST DO THIS PLEASE- GET THE MANUAL FOR THIS UNIT!!!! And READ IT FIRST!! Find in the manual where it walks you through putting the UPS In bypass (Static Bypass). Follow the manual, My way of doing is to READ TWICE, OPERATE UPS ONCE!! This has help me not dump any loads. My suggestion to you is to check if unit is in Bypass (static Bypass due to the faulty module. If it is on Bypass then all you need to do is follow the procedures to place UPS in External Maintenance Bypass. If UPS is in Normal mode but with Alarms and Beeping, then Navigate through the display and find the BYPASS Mode. Then hit enter Yes on the BYPASS MODE, it will ask you again if you want to "Place UPS INTO BYPASS. Hit YES. You will hear it click. Your LED on the display should Light UPS Solid "BYPASS LED ON" AGAIN Please keep referring to the MANUAL. Once your in bypass mode (Static Bypass) then you can operate the External Bypass Switch on the bottom of the UPS. That is the Maintenance Bypass Switch. This isolate the UPS completely and your load never see's the transfer from Static Bypass to External Bypass, Because its a MAKE BEFORE BREAK System. (Make the power before Breaking the Power) Sorry to get down to simple terms, but when I work on a UPS its personal due to the fact you are responsible for the all that is on the OUTPUT of that UPS. Once on External Bypass, You can now do you module swap. Turning the UPS back on, Please follow place UPS back On Line in the UPS Manual. Also in the Diagnostics, off the display of the unit, it also identifies what module is bad including the Power Modules to the Battery Modules.
Nov 03, 2010 | APC Symmetra Tune-UPS technical support -...
How to take ups in manual bypass mode.
You definitely want to follow the manual procedure to avoid a possible load loss:
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9390.aspx?cx=3
9.1.4 Transfer from Normal to Bypass Mode
To transfer the critical load to Bypass mode:
C A U T I O N
In Bypass mode, the critical load is not protected from commercial power interruptions and abnormalities.
1. Press the CONTROLS pushbutton on the main menu bar. The System Controls
screen appears.
2. Press the BYPASS pushbutton on the System Controls menu bar.
The UPS transfers to Bypass mode and the critical load is immediately supplied
by the bypass source. If the bypass source is not available, the power processor
remains on and an alarm sounds.
3. The UPS is now operating in Bypass mode and the BYPASS status indicator is
illuminated.
The power module (PM) status indicates READY. The system is now on bypass
and the UPS power processor remains on.
At this point, you can operate an external bypass switch to get to maintenance bypass if needed.
Oct 14, 2009 | Eaton PW9390 UPS System
The bypass mode indicator is blinking, what do I need to do?
my be its indicating that the bypass mode is not available because power input is not of range that the ups is designed to take, check the ratinng of ups and use amultimeter to check whether the input matches the input. also depending on the type of ups this could be a code for a fault. please avail the ups type.
Oct 13, 2009 | Powerware 9125 UPS System
Bypass LED on the ups is on
This an excerpt from the UPS's manual:
The Bypass LED illuminates indicating that the UPS is in bypass mode. Utility power is sent directly to connected equipment during bypass mode operation. Bypass mode operation is the result of an internal UPS fault, an overload condition, or a user initiated command through an accessory. Battery operation is not available when the UPS is in bypass mode.
Jul 19, 2009 | APC Smart-UPS 1000VA UPS System
Bypass procedure SL20KHB2
First Press the user menu button
then scroll up or down till you reach on put UPS on bypass? Press C to change to YES if the default is already YES just press the # button then the UPS will go on bypass mode.
Go to UPS bypass panel and turn the bypass switch to (1) ON and Switch the Output on the bypass panel to off. Now you're already on a bypass mode.
if you have any query please drop me an email.
Thanks
Feb 20, 2009 | APC Silcon UPS System
Compaq 204015-001 - UPS T700 - UPS - 700 VA - UPS battery (204015001UPS) UPS System Logo
261 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
