Question about Kitchen Ranges
Oven won't work
The oven worked fine (propane) Now it won't ignite. I don't know what caused this. This is located in a rental property so I don't know anything except what they told me. The top burners work fine but the oven does not. What could cause this? Is there a pilot light, or some kind of safety switch in case they ran out of fuel ? I realize I don't have much info so anything will help. Also what are some good ways to troubleshoot this? Thank you.
  • 2 more comments
  • Anonymous Dec 17, 2007
    oven pilot is on BUT oven will not come on. TM210
  • TrishS Jan 27, 2008
    Yes, I too have the same problem. Oven will not lit, but the burners on top of the stove work fine. Is it just replacing the igniter? The broiler works fine. And how big of a job is it to replace the igniter? I have a GE Profle Spectra XL44.
  • gkelly22 Aug 08, 2008
    I have the same problem. The top burners work, all of the displays work, the broiler works - but the oven doesn't heat.
    Is this a simple fix or do I need to call a service person?
  • annavillarea Nov 15, 2008
    same thing with our GE oven - called repairman - are we in danger of the gas leaking and harming us?
  • 262 Answers
The gas valve has gone bad replace valve and igniter at the same time the older igniter will not have a value (ohm) to pull in the new will also have to turn on burner after installing new parts and adjust the flame using the brass fitting on the valve going to the burner assembly.but before you replace any thing make sure you have fuel to the range good luck
Posted on Dec 17, 2007
I have an arr3140ss American gas range. Just recently installed new burner and igniter.Roasted and baked all last week no problem todayI turned on the overn abd got up to 550 for pizza. put pizza in
Sometimes the pilot light goes out on this type of oven. This could be caused by a draft, or sudden jolt. Even if the top burner is working, the bottom won't go on until the pilot is lit. Check your manufacturers' instructions for locating and re-lighting the pilot.
Best of luck.
Nov 30, 2014 | Kitchen Ranges
I have two magic chef model 6157wuw ranges in my house which operate on propane. The stove burners work perfectly however the ovens produce no heat, no smell of propane and no sign of a pilot or glowing...
It sounds like your propane line is obstructed or your igniter has failed. If your igniter has failed, the propane will not flow until a heat source, from your igniter, has heated a sensor to let the unit know to allow propane to flow. If the propane line is obstructed, it is probably a spider web or eggs from an insect. A pipe cleaner is the best way to remove these obstructions. It would be advisable to have a qualified technician look at your unit.
Sep 21, 2013 | Magic Chef Kitchen Ranges
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 | Ovens
The oven lights up, but the oven will not reach temperature and it smells of propane. The burners work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
Feb 24, 2011 | Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Gas oven will not ignite
I would be suspect of the temperature control valve based on your previous experience. I am assuming the safety valve you are speaking of was really a regulator.
Jan 28, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Kitchen Ranges Logo
416 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
