Question about Dell Vostro 220 Desktop Computer
There was a temperature change of -2 degrees farenheit each hour over a period of 5 hours. In all, what was the temperature change over the 5-hour period?
  • 102 Answers
Temperature change because your HEATSINK on your Procceccor is not good anymore.
Remove your Procceccor,Clean up Heatsink on your Procceccor and Fan,and give a new heatsink to your procceccor and fan.
you can found a HeatSink in a new Fan Procceccor.
but if you can't found a Heatsink,
you can use a tooth paste.
Posted on Sep 26, 2009
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
Freezer is set on -2 degrees, actual temp in freezer is -20. What sensor is causing this problem
I suspect that you do not have a problem. . The standard operating temperature of a freezer is around -20 degrees CENTIGRADE (-2 Farenheit)
Your freezer has an option to display degrees C and degrees F, I suspect it is showing farenheit
I have taken a look at a copy of the manual, which can be found at:
http://www.manualowl.com/m/Samsung/RF217ABBP/Manual/142915
But for the life of me, I can't see how to change the display from C to F and back anywhere in the guide. If I am right, swapping the display back to Farenheit will solve the display issue.
If you are unable to change the display, you can try calling Samsung in arlington NJ on 1-800-726-7864.
Hope this helps. Please add a comment to this thread to let me know if the problem is solved or if you need more help
Sep 15, 2011 | Samsung RF217ABBP Bottom Freezer French...
What is 20 celsius in farenheit
Hi jujaramirez,
Have a nice day.
Here is the formula to compute farenheit to celsius and celsius to fahrenheit:
C is Celsius
F is Farenheit C = 5/9 (F-32
F = 9/5 (C+32
Let's try converting 68 degrees Farenheit to celsius 5/9(68-32)
Step 1: 68 less 32 is 36
Step 2: 5 divided by 9 is 0.5555555555555
Step 3: multiply the repeating decimal by 36
Step 4: your solution is 20
Now, convert 20 degrees Celsius to Farenheit to check your work.
9/5C +32
Step 1: 9 divided by 5 is 1.8
Step 2: 1.8 multiplied by 20 is 36
Step 3: 36 plus 32 = 68
Hope it answers your problem.
Thank you for using fixya.
Adieh
Sep 13, 2011 | Health & Beauty
Ultronic clock, humidity & temperature. How does one read the "Temperature Trend" scal on the lower left of the screen. There are three scales shown and the indicators on the scale keeps...
This clock keeps track of the temperatures for each of the last 12 hours. So on the bottom, you'll see the temp at 12 hours ago (-12), 6 hours ago (-6), etc. On the left side, you'll see the temperature in Farenheit go from +5.4 to -5.4 from where it is currently. So if the temperature is 70F degrees right now, and it was 65F degrees 12 hours ago, then it'll show -5 in the first -12 column. It will always be at 0 for the current hour on the right. The scale on the right is in Celcius so it does the exact same thing as Farenheit.
Mar 01, 2011 | Watches
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
Step 2
Step 3
Step 4
Step 5
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
I want to use two independent Sub procedures: One to convert a temperature from Farenheit to Celsuis, and the other to convert a temperature from Celsuis to Farenheit
Save this as a vbscript (filename.vbs) and modify the language as needed. Should be pretty self explanatory let me know if that works.
Sub ConvertTemp()
temp = InputBox("Please enter the temperature in degrees F.", 1)
MsgBox "The temperature is " & Celsius(temp) & " degrees C."
End Sub
Function Celsius(fDegrees)
Celsius = (fDegrees - 32) * 5 / 9
End Function
Function Fahrenheit(cDegrees)
Fahrenehit = (cDegrees + 32) * 9/ 5
End Function
Apr 05, 2010 | Computers & Internet
The furnace won't stop at the programmed temperature set ponts
this is called a swing tempature it is desined to improve the eficincey of the frnace because it take less energy to run an hour in a three hours then 3 bursts of 25 min in a three hour period
HOWEVER if you do not like this you can usualy set the swing temp
Jan 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
Dell Vostro 220 Desktop Computer   Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
