Question about Canon Rebel XT / EOS 350D Digital Camera
"busy" in all modes except non-flash setting on 300d
As the title describes, I get a "busy" display when trying follow through on a picture in all modes execept non-flash mode (all the way on the bottom of the dial when turned clockwise). When I turn it on, select a mode and press the shutter button halfway to prep to take a picture, the flash opens up, I get autofocus and then I push the shutter button fully and I get a "busy" display. After awhile, it turns to 'err 99' display. What's your take on this?
Marc
    Novelist:
  • 148 Answers
Bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
mark
Posted on Dec 23, 2007
2 Suggested Answers
chansimon
  • 42 Answers
SOURCE: Getting "busy" display on all modes except no-flash mode...
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
Posted on Mar 07, 2008
I have a Panasonic DMC-LX2 digital camera, I'm based in the UK. Has worked fine for a couple of years, but 2 weeks ago, when powered up, none of the buttons work. Screen is illuminated, lens emerges OK,...
I just got identical situation today, and I have no clue at all. However, I figure that the camera is actually working busy like someone is holding the "UP" button continuously. To see this, power on your camera at any mode except the "Scene mode". After it's on, turn the mode select knob to "Scene mode". I saw my camera menu flashing like crazy. When you press any button, the menu should stop running. But once you don't press the button, the menu start running again.
Please let me know if you have any update.
Sep 21, 2010 | Cameras
Flash not working
Assuming that you haven't put the camera into a mode in which flash is disabled, either the charging capacitor or flash bulb is defective. It will have to be serviced so the appropriate part can be replaced.
Dec 03, 2007 | HP Photosmart 850 Digital Camera
Canon ds6041 digital rebel problem with AF 70-33 mm
Try cleaning the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 31, 2010 | Canon Digital Rebel / EOS-300D Digital...
Canon 300d flash won't fire. Pops up ok but display just reads "busy" and camera locks up. Must turn on/off to get camera working. External flash works ok.
This may sound obvious, but have you tried to make surer the battery is fully charged and then see'ing if it still does this? The reason I suggest this is that I had a similar problem and when I fully charged the battery this problem went away. I tend to keep an extra battery (fully charged) plus the charger on hand at all times.
Dec 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
Dec 05, 2008 | Canon Digital Rebel / EOS-300D Digital...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Dec 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
Eos 300D. THE FLASH DOESN`T POP UP
there is a setting that tells the camera to use flash or not to. refer to manual. its simple to remedy.
good luck
mark
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Error 99 only when flash pops up
I know what you two are talking about. I ordered a Canon EOS 300d from a site called "Keh" and I had never used one before... so I get it in the mail on time. The camera works fine for a few minutes then I get an "error 99" and can't do jack with the camera. I researched online and even called keh ... I read and heard that it has to do with the lens... so I sen't the camera back and got my money.
Nov 26, 2007 | Canon Rebel XT / EOS 350D Digital Camera
EOS-300D Flash
your flash is acting to 'fill' for you. fill lighting can be a benefit. if you don't want it, see settings menu to turn off flash until you need it. not difficult and worth knowing how to make simple routine setting adjustments.
good luck
mark
Sep 20, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
337 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
