Question about Frigidaire FMV157GM Microwave Oven
The handle on the door has broken at the bottom. It looks like an easy fix if I can just figure out how to get it apart without breaking it further.
  • 5,911 Answers
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door. If the model number you have this listed under is correct, I found a replacement door handle at repairclinic.com for about $25. Look for item #1381096.
Posted on Sep 25, 2009
Testimonial: "Very helpful. I saw no screws holding the door together, so instead of prying with a risk of damage, this information was great."
Following your instructions and it worked like a champ!!! Thank you, Kimmie
Posted on Nov 10, 2012
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Jan 16, 2011 | Microwave Ovens
Trying to replace the KHMS155LSS3 handle...
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs._828.jpg_829.jpg_830.jpg_831.jpg
Jul 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Getting door frame apart to install new handle
If you're replacing the handle, then order the choke cover..It's the piece on the inside of the door that covers the handle screws. No matter how carefull you are, it is almost guaranteed to break. If you break it, then you have one, and if not, send it back. DO NOT OPERATE MICRO WITHOUT CHOKE COVER.
Dec 09, 2008 | Kenmore 62702 Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Broken handle
1) Have to remove the door first; top of the oven there are two screws closest to the door, take those out. and the door should lift out
2) flip the door on the table with the handle side down. starting on the handle side there are three clips (top, middle, and bottom) between the outside casing and inside trim. Using a thin screwdriver gently twist starting at either the top or bottom to pod the two casings apart. work your way around the door.
3) You should see one of the screws that hold the handle on (top) but the bottom screw is under the metal casing so you need to remove the screws around this casing as well to get the other handle screw off.
Once you start you will see it isn't as bad as this sounds. I bought the handle for $40.
It is a shame that this is so cheap and breaks off this easily. Surprisingly we have had ours for at least 6 years before the handle broke and we have 3 girls opening and closing this all the time so I guess I was one of the lucky ones.
Hope this helps and good luck
Nov 20, 2007 | GE Advantium 120 Convection/Microwave Oven
Spacmaker xl sensor
Same goes for me. I can get most of the trim off but not the area near the hinge. ! It will cost $100 for GE to come out, and I already own the new handle. Come on GE tell us the secret.
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FMV157GM Microwave Oven Logo
538 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
