Question about Dell Dimension 2350 PC Desktop
When I Boot up it Dosent display the screen Any
When I Boot up it Dosent display the screen Also To Turn On The Pc I Have to unplug and plug back in
  • haz_n_chezz Sep 25, 2009
    If This Helps When i turn on with the screen plugged in no power light, when no screen is connected power lights are on
  • haz_n_chezz Sep 26, 2009
    Well iv Tried Loads of monitors and nothing but thanks any way
  • 102 Answers
What you've plug ?
if what you mean is a socket monitor to VGA port,
i think you have a problem with your monitor.
try to use another monitor if U have one.
boot up doesn't display ?
go into BIOS setup,look for "load BIOS SetUp Default or Load For Best Performance".
Choose it,Save and Exit.
Posted on Sep 26, 2009
    Scholar:
  • 78 Answers
Do you have any external USB drives connected? Older enclosures can cause a problem with resuming from sleep / hibernate.
-Jon
Posted on Sep 25, 2009
Black screen won't boot up
1.) unplug system
2.) remove side panel
3.) remove the battery from on the main board
4.) press and hold the power button for 30 seconds
5.) replace battery, plug in system
6.) turn on
7.) enter the bios by pressing the enter setup key displayed
8.) restore default settings, save and exit. (optimized settings work great)
Dec 26, 2012 | Acer Veriton Z290G 185 320GB
Display screen
Assuming it's an ipod check the hold switch turn it on & off. If it's plugged in to pc can you transfer music? Have you tried to reset it? If so let itunes update the software.
Aug 22, 2012 | Audio Players & Recorders
Mdr515h dosent work
Sounds like you need to do a "Hard Reboot" . . . Unplug the power cord and let it sit overnight, then plug it back in and it should work for you.
Jan 11, 2012 | Magnavox MDR515H HDDVD Recorder
When i try to open the only respond i get was the continue blinking of the laptop no picture is benig showned in the monitor
Shut down your laptop and try pressing the center of the keybord just center of your screen firmly gently and then start the system if its ok the display comes back you are having problem with the heat sensor of the display card and not coooling properly .so loosing the display.
BUT if you mean there is a cursor blinking on the screen and dosent have display then your boot devices are configured improperly and so its searching for boot device .
also it happens when usb boot is enable in the bios and any usb device is connnected like flash or usb hard drive try to remove them and restart the pc.
Dec 13, 2010 | HP Compaq Presario CQ50-110US Laptop
Computer fans come on wide open drive light blinks 5 times but no boot at all the power light dosent even come on
make sure the hard drive cable is plugged in good and the power button is as well. then unplug the power cord from the supply and take the cmos battery out. before you plug it back in hold the power button in for about 30 seconds. Put the cmos battery back in make sure all of your ram is seated well as well as video and wireless cards. Plug the cord back in and give a shot Might just need a hard boot.
Dec 07, 2010 | Gateway GT4016 Desktop PC
My computer starts up and immediately shuts off. Most say its a hardware issue, tried a host of possibilities but the motherbaord being replaced. Suggestions?
Unplug the computer and open the case. Take a picture of the cards in the slots, and then remove all of them except the videocard (the cable that connects to your screen) if you have one that isnt built into the motherboard (be sure to label the connectors going to the cards if you're unsure of what they are) and then power the computer back up.
If it works fine one of the cards is bad. (If it dosent, skip down 1 paragraph) Turn the computer back off and unplug it, plug 1 card in and turn it back on. If it works, shut down and do the same for the next card. Keep going until you find the card that is killing it.
If it still dosent work with the cards out, it could be the power supply or something on the motherboard. Unplug the PC again and turn it on without plugging it in, this will drain the caps on the board. Holding the computer case with one hand (or use a ground strap) remove the memory from the sockets. Plug the computer back in and turn it on again (dont reach inside, fans and wires that are powered up). If it still does the same thing, it's the motherboard/cpu, if it beeps at you, it's the power supply.
Apr 27, 2010 | E-Machines eMachines Desktop PC
Hp Pavilion a350n shutdown and will only boot up to a blankscreen, (no Windows logo) there is not beep, no indication of any problem, power is good, video card is good (tried three cards), switch monitors,...
I assume by power is good you mean when you press the power button on the pc it spins up.
1) unplug all the components such as hard drive, floppy and USB from the motherboard.
(so you should only have the VGA, monitor and motherboard with RAM and CPU.) turn it on and see if you get a screen. if you don't there is possibly a problem with the motherboard.
if you do get some display on the screen 2) switch off and plug in one component at a time and then switch back on. if it works turn it off and plug in the next component and turn it back on. repeat until you find the faulty component that cause it to not turn on.
Dec 16, 2009 | HP Pavilion a350n PC Desktop
My acer aspire e500 has no hard disk aactivity
Try to discinnect CD/DVD driver also when you power on main cor dont instantly power on case, wait 5 minutes and then try. Such kid of failureas are causer by power adaptor system. Also try bios reset put off battery and wait 5 minutes to reset CMOS also power cord must be unpluged. Unplug and plug power sources to mainboard. then turn on.
Jul 30, 2009 | Computers & Internet
Won't boot up past the Toshiba screen
Unplug any external devices. Remove additional memory if added. Take out battery and unplug ac adaptor. Press power button and hold for 20 seconds. Plug it back into the mains and try to turn on again. If this will not work replace mainboard.
May 26, 2009 | Toshiba Satellite Laptop with AMD Turion...
Dell Dimension 2350 PC Desktop Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
