Television problems I have a sanyo model DS19390 and it began to make a buzzing noise. The picture and sound are fine it just makes a loud buzzin noise.
    Problem Solver:
  • 7 Answers
I have same model and same problem just happened to me. TV repair shop said it was capacitor $40 to fix.
Posted on Mar 20, 2014
    Problem Solver:
  • 11 Answers
Have the speakers ever been played loudly? They may have been pushed passed their capacity, in which case, it may be time for a new tv.
Posted on Dec 16, 2007
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
A loud buzzing is coming from the back of my sanyo ds 25390 tv. picture and regular sound is fine
If it is a high pitched whine or buzz it is likely a transformer vibrating so hard it is making the noise.
There are ways to try to deal with this issue but the set has to be opened and probed to locate where it is coming from--
for example with back off and set on a plastic rod can be used to touch areas and exert slight pressure until the sound changes or goes away--then either replace the part or I have used hot glue etc to stop it.
You first have to locate the source of the issue:
find where it is coming from.
Mar 24, 2012 | Televison & Video
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Jun 06, 2010 | Sanyo AVM-1909S TV
Buzzin on my web cam mic
check all your grounds. Is the computer outlet have a proper ground? Sometimes if your using a sound card make sure its grounded to case of computer.Make sure cable that feeds mic is not laying over a 110v cord as that can pick up a 60Hz buzz or hum noise as well. Hope this helped sometimes its trial and try again....
Jul 22, 2009 | Electro-Harmonix EH-TM Microphone
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
Sanyo projector began making a humming noise when running
Its probably the fan inside is loose, try cleaning the fan. or press the machine by your hand to where the sound is coming from, then you will know if there is a loose screw
Oct 28, 2008 | Sanyo PLV 60HT Multimedia Projector
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Buzzzzzzz
Hello to all you buzzers, I have the answer to your problem. First this is what's happening. The buzzing is coming from the power relay. It vibrates at 60hz because the power supply filter capacitor is not doing its job hence you have a rough d.c. pulse going to the relay.To solve the problem remove back of t.v. slide circuit board out (you will have to disconnect white wire from degauss coil,located on left front) look for a blue box approximately 3/4"x1 1/2" this will be the power relay. Now look for capacitor location #c622 near the relay. This capacitor should be 470uf 25v. Remove and replace with 470uf 35v capacitor, connect white degauss wire temperarily put back on and give it a spin. Hope this solves all the buzzin,robert
Jul 12, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
374 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
