Question about Konica Minolta bizhub C351 All-In-One Laser Printer
When I scan 4x6 images from the automatic feed on the top of my bizhub c350 and then open that file there is white area around the outside of the image. Is there a way to scan these images so only the image is saved in the file?
  • Konica Minolta Expert
  • 158 Answers
This is a machine limitation. Sizes smaller then 5.5x8.5 are not recommended to be feed through the Document Feeder and can not be guaranty proper
operation.
Posted on Oct 27, 2009
Steps to install c350 and the drivers
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Jul 08, 2015 | Konica Minolta Bizhub C350 Digital Copier,...
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Bizhub c350 copies faded in the middle of the page
    Does this happen when the orginal goes thur the doc feeder? place the orginal on the big glass does it happen then? Your optics mite need cleaning MIRRORS in the machine scanner section or the Image unit need repair or replacement.
    Jan 08, 2010 | Minolta bizhub 350 Black and White Copier
    I want to scan to a file on my server with my bizhub c350 I do not know how to do that.
    You can create a scan to FTP one-touch.
    log into the device by entering the IP address into your web browser.
    From here you can create, edit and delete one-touchs of various types.
    Dec 15, 2009 | Konica Minolta bizhub C351 All-In-One...
    Konica Minolta bizhub 250 jammed but no paper
    Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
    Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
    Unable to print in colour using GIMP
    if i am correct the bizhub 350 is for black and white only and not colored, unless you use a bizhub c350
    Apr 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
    Bizhub c350 will not scan to hdd
    Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
    Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
    Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
    Hello
    Yes, there is no 4x6 choice, you have to input costume size.
    For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
    Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
    Konica Minolta bizhub C351 All-In-One Laser Printer Logo
    54 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    Ben
    Ben
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
