Question about Cell Phones
The unit does not charge, why? - Cell Phones
Cant findwhere to charge ac
if it is a window unit you are trying to charge - chances are - there are no charging ports. Hardly any window units (that I know of) have charging ports when manufactured. The only time you'd find charging ports on one is if it had been 'charged' at some time in it's past history. Most window units run years and years without needing to be re-charged. Therefore - if you cannot find charging ports it means it's never been charged since being manufactured. Always 'be sure' a unit needs charging before opening the system.
Through the wall units (like in motels) sometimes - comes with charging ports - although not all the time.
Central units all have charging ports and they are located on the condenser (outside unit). Just follow your copper lines (one big one -usually insulated and a smaller one) - into the unit and the charging ports are not easy to miss.
hope this helps.
Jun 18, 2011 | Heating & Cooling
How to write an electricity bill in c program(9'th class)
#include <iostream.h>
#include <conio.h>
int main()
clrscr();
long int units,charge=0;
float total;
const int rent=25;
cout << "Enter the number of units used : ";
cin>>units;
if(units>200)
charge=(units-200)*20+150*40+50*60;
else if(units>50)
charge=(units-50)*40+50*60;
else
charge=units*60;
total=0.01*charge+rent;
cout << "You have used " << units << " units." << endl;
cout << "Your total telephone bill is $" << total;
getch();
return 0;
Please accept the solution. Thanks, Lucy
This program takes in the number of units used ('units') as a screen input from the user.
It then calculates the total telephone bill for the customer on the following basis :
A compulsory fee of $25, plus
60 cents per unit for the first 50 units,
40 cents per unit for the next 150 units,
20 cents per unit for anything above 200 units.
It then outputs the bill using the 'cout' command.
Jan 12, 2011 | Microsoft Computers & Internet
I have an ION Tailgater which doesn't seem to be charging. The unit power doesn't have to be on whilst charging, but approximately five seconds after plugging in to charge, the charge light goes out, and...
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
Dec 20, 2010 | ION Audio Tailgater Portable PA System...
Base unit not charging phone
hi,
if the base unit is not charging phone,did you test it with another phone to confirm if the base unit is working?
if after doing this and the base unit is working confirm if the d.c. power is okay, because if the current is low, the base unit will not charge the phone.
if after doing all these and the phone is still not charging, then, your charging port is bad.
you have to replace the charging port with a good one.
the charging port is the place where the base unit will enter.
i hope i have answered your question correctly?
thanks for using fixya
Jun 08, 2010 | Lands Phones
My gamin won't charge
FIRST, make sure you have the charger recommended by Garmin. I made the mistake buying a cheap brand and it didn't work. That was a waste!
Next:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Jan 18, 2010 | Garmin nuvi 200W GPS Receiver
How can i charge my nuvi garmin 310 and how long
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FIRST, make sure you have the GARMIN approved charger!!!!
Nov 30, 2009 | Garmin NUVI 360 GPS Receiver
Need to know how to charge garmin nuvi 255w using home wall charger.
Jun 26, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on ...it did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
And:
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
Unit won't remain powered-up
You are absolutely correct Jim. Low Battery
Dec 25, 2008 | Garmin nuvi 260W GPS Receiver
Psp battery won't charge
Its a problem with the unit's charging pins..you will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
