Question about Linksys Wireless-G Broadband Router
Lost passphrase I have lost the passprase for the wireless router ... how can I reset it?
  • 496 Answers
There should be a reset button on the back of the router press and hold that for about 20 seconds once thats done then you should be back at the default password of admin with no username
Posted on Sep 30, 2009
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Dont no my wpa pass phrse
It's common for us to forget passwords the problem is when you need them:) It is simple to correct this problem but you need to connect directly to the router via a hardwire (ethernet cable). If you haven't changed the default IP setting on the router your going to do the following. Through your Internet Browser your going to type in the IP address of the Dlink router in the address bar. This default IP is 192.168.0.1 You will be prompted for username and password. By default that is Admin and password blank (nothing). Once logged in you will choose from the Dlink menu Setup then Wireless Settings. At this point keep it simple use the wireless wizard to re-create a new passprase for your WPA. By the way update your laptop as well. Some old wireless drivers don't work properly with WPA passprase and make it apprear your passphrase is incorrect when its fine. Good Luck.
Jun 28, 2011 | D-Link DIR-615 Wireless Router
We cannot log on with the assigned password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
hope this helps
Dec 30, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Netgear will not reset to factory
sir a hidden button on the back of the router used to reset to the factory default settings (use paperclip)
thanks
Nov 25, 2010 | NetGear WGR614 54Mbps Wireless Router...
Want to put a password to my router
Nov 08, 2010 | NetGear WGT624 Wireless Router
I have forgot my wpa security password,i have tryed to reset my router,but im not having much luck,cause i dont understand it all.when i follow the instrsuctions what the person onm line tells me to do,i...
Nov 07, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Passphrase recovery
If you are using a Linksys Router like the one pictured hold the small reset button located on the back of the router while you are plugging it in. After it boots up the password should be the default and the wireless will be unsecure so it will have to be reconfigured unless you have saved the setup to a computer. password should be admin with no user name on most models.
Mar 09, 2010 | Linksys Wireless-G WRT54GS Router...
Just came home with an acer laptop its asking for my passphrase or security key i don't have a clue what it is or where to find it got a dell xp home edition desktop
passphrase or security key deals with wireless internet if you are not using this then disable the wireless card this can be done Holding down FN on left side of keyboard and then Pressing the Function key at the top that relates to wireless it will have a little tower on it. only do this if you are not going to use wireless if you are going to use wireless you will need the passprase and security keys.
Nov 28, 2009 | Actiontec GT704WG Wireless Router...
I lost my passphrase of my dlink router
There should be a reset button located on the back on the router. Hold on that button for about thirty seconds or so and resetup the router with the password.
Nov 14, 2009 | D-Link DIR-615 Wireless Router
Linksys Wireless-G Broadband Router Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
