Fuse keeps blowing on my Sherwood RV-5050R Receiver
    President:
  • 1,114 Answers
Disconnect all speakers at the receiver, then replace the fuse and check power again. If your lucky, it will be ok. More than likely though, the power transformer and capacitors have been shorted by a voltage spike or drop. If you don't have a good line conditioning surge like a Panamax, APC, or Furman, get one! it will save you $$$ and aggravation in the long run. Hope this helps.
Posted on Sep 26, 2009
Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Jun 19, 2010 | Sherwood RV-4050R
I have a hi fi system of separate components - amp/receiver, cd player. Occasionally when listening to either radio or cd a pop or bang (a bit like a gunshot) is heard and the amp switches off. Is the...
Make sure the speaker wires are not touching at the back of the receiver or at the speakers. Make sue the cable(s) connecting the two is not damaged or shorted. If the wires are ok then the amp/receiver is the problem. Possible bad capicitors are the problem in the amp.
Jun 17, 2010 | Sherwood RV-5050R Receiver
Sherwood model RV 5050r - tuner is not holding radio frequencys in memory when the main switch is turned OFF and ON again. Is there a battery that needs replacing or a chip?
Try looking for one of these Memory Retention Capacitors, they cause a lot of trouble like that. It will be in the tuner section somewhere if it uses one. It could look a bit different to this one, so bare that in mind.
Mar 06, 2010 | Sherwood RV-5050R Receiver
Sherwood RV-8070R, i can t switch it on
TRY BLOWING IT OUT WITH A AIR COMPRESSER
May 13, 2009 | Sherwood RX-4109
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
No High Voltage
I did solve the problem with the Sherwood receiver R6036-R
The problem was a broken solder Trace towards the power cord on the powersupply board.
Thanks for your concern
May 30, 2008 | Sherwood RVD-6095R Receiver
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
No sound
it may be an internal fuse which is see through be aware that you put in the same rating fuse if you need to replace them
Mar 22, 2008 | Sherwood RV-5050R Receiver
Dont have manuel
Try this link:
http://www.sherwoodusa.com/cc_manuals.html
I didn't see the RV-5050R on the website, but you might try
the RV-4060 manual. It is the same series at least
Mike
Nov 06, 2007 | Sherwood RV-5050R Receiver
427 people viewed this question
 Grubhead
Grubhead
