Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My gas lines cracked and i do not no where they go and i dont no how i go about troubleshooting it
  • bbreton
    bbreton May 11, 2010
    Need to know a model number on the unit? Plus before you send good money for parts take to a good shop and have them do a compression test on the engine. You would not want to spend money on something that may take more than a few dollars to get running.
  • bbreton
    Need to know what model of trimmer you have to help you solve this problem. I would look at getting a compression check on the engine to see if the engine is okay before spending any money. If the engine compression is no good, the repairs to fix it exceed the cost of buying a new one.
  • 148 Answers
  1. The line from the tank with the fuel filter goes to the bottom port of carb.
  2. The top port on the carb goes to the suction port of primer bulb (To tell which port is the suction port put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the suction side).
  3. The outlet port of the bulb goes to the non-filter side of the fuel tank.
Posted on Oct 15, 2009
How do i fix my motorcycle honda wave dash fuel gas not continous flowing if i fixed the gas cover
Hi, Danilo always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won run All about Scooters
http://www.scootertherapy.com/startinghints.html
My chinese scooter wont idle or start Check the fuel petcock
http://part-centre.boonsiewhonda.com.my/pdf/catalog/wave%20dash_new.PDF
Honda Wave 110i User Manual
Aug 31, 2016 | Honda Motorcycles
It leaks when the car is on and when the car is off i can see it running down the fuel line there is not a lot of gas in the car so i dont think is the tank
fuel lines could be cracked on the tank top. if its not had them changed then would think it would be this. as over time they split and crack. and 92 modle would think it was this.
Jan 21, 2014 | 1992 Subaru Legacy
Polaris snowmobile troubleshooting
check the gas lines where they all come together, They crack there and can leak when fuel pump is working
Jan 02, 2014 | ATVs
No gas go true the lines and the pilot dont keep on
Crack the union and make sure the line is pressurized
Dec 09, 2013 | Ruud UAMB Air Conditioner
Evap system problem
usually a bad gas cap if that doesnt solve your problem you can trace all the evap lines going from your gas tank forward looking for cracks if you dont find any cracked or broken lines you may have to take it to someone with a smoke machine to put smoke through the lines to find your leak. try the gas cap first. if this was helpful please leave me good feed back.
Apr 28, 2013 | Ford Escape Cars & Trucks
I have a Ryobi Leaf Blower (Model 310 BVr) which
Look for a cracked fuel line, or a loose fuel line around the fuel tank. I'm going to lean towards the cracked fuel line.
Feb 01, 2010 | Ryobi Garden
Gas flows continuously from the overflow line
dont know much about bikes, but it sounds as if the float is stuck open
Dec 31, 2009 | 2005 Yamaha TT-R 125 L
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Fuel problem
take the gas cap off and look into the tank and see that the fuel filter is on the bottom of the tank and still secure to the fuel line.
Your tank will be slightly pressurized be sure your gas cap gasket is there and pliable.
same for your gas lines be sure they are relatively soft and dont crack easy if you move them?
try these couple items and see if any will help the cause
Jun 10, 2009 | Mantis 2-Cycle Tiller
Leaking gas line in 1992 4 door Honda Civic
yeah,
get a rubber hose that is just a little bigger than the gas line. slice it and wrap around hole. clamp tight with hose clamp *NOT TOO TIGHT THOUGH* you dont want to bend the line or crack the tubeing.
Jul 01, 2008 | 1992 Honda Civic
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
160 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
