Question about Garden
Kohler command 20 Hp. engine on walker mower having problems with the electric starter sticking, requiring removal every 20 hours or so to clean dirt,grass and such in order to return to normal operation. Any suggestions ??
I have had the same problem on my Walker mower for two years. I sometimes have to turn the key 20 to 40 times and then it will start. I have never taken it off to clean it, but I do notice when I keep it blowed out and keep the connections from the battery and all cables tight, then it starts better. As long as it keeps starting, I'm not taking it out.
Posted on Mar 06, 2013
  • 472 Answers
You can lub it up with some 3m oil if that dont fix it than it may need a new one
Posted on Oct 01, 2009
I have a 6200 Woods zero turn mower with a 20 hp Kohler Command. Runs anywhere from 5 to 20 minutes then shuts down. Put an electric fuel pump on it, no change. Good compression. Good spark.
Dear Doug,
There are three reasons you could get "run-on".
Probably you have one or both as your problem concerning the 5 - 20 minutes automatic shut off.
1) The timing is off, causing the engine to have a tiny bit of gasoline left over, which is just enough to give power to keep running.
2) The engine is getting too hot, which again causes it to keep on running after the key is shut off.
3) If the engine has a carburetor, the needle & seat could be dirty or sticking,or the float sticking, causing it too have too much gas, and that will keep it running.
God bless your efforts to fix this.
Oct 24, 2017 | Cars & Trucks
Why oil consumption on kohler command 20
Either badly seated oil rings or PVC valve is stuck open allowing oil to enter through carburetor.
Oct 20, 2014 | Kohler Command OHV Horizontal Engine with...
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
How many hours of use can I expect to get from this mower?
the more you do maint on it the longer you will get oil changes filters shape blades help engine load do you ever take off the top cover and clean the cooling fins?do you climb hills?use it to pull loads arouund the yard?but the 20hp kohler engine has had problems cracking the block on top of the engine my mower has a 22hp kohler with 2236hrs on it starting to get tired
Jun 07, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
892 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
