Question about Maytag MLG23PD Gas Commercial Dryer
A paddle on the tub has come off. How can I re-attach it?
  • donhow Sep 25, 2009
    I understand. I need to know the procedure for accessing the area.
    President:
  • 1,462 Answers
The screws for the paddle can be accessed by removing the small back panel.
After removing the screws, you can pud the new paddle and tighten the screws..
PLease leave me comment, if you need furthur assistance, else rate this solution
RNJ VINODKUMAR
Posted on Sep 26, 2009
  • 2,841 Answers
Sadly the only way to reattach it is from the outside of the tub. In other words from the backside of the tub you cannot see. You may be able to lay the dryer down and reach it, or you may have to remove the back. You may also have to remove the tub altogether.
Posted on Sep 25, 2009
How do I fit a drum paddle to beko wma 767s
The paddles are normally fitted from inside out of the inner tub. You will have to strip the whole machine down to remove the inner bowl and then you can get to the fitting which holds the paddle in place.
Apr 08, 2015 | Washing Machines
Why does my LG washing machine make a rattling noise even at low RPMs?
It is not uncommon for items that get loose in the washer (paper clips, coins, etc.) to slip underneath the "paddles" and then make noise as the drum turns. While an annoyance, it is not anything to be overly concerned about. Eventually the item(s) will come back out.
Mar 19, 2015 | LG WM-2277HW Front Load Washer
Remove loose change from washing machine
Depends where the loose change is? Some times it caught between the middle paddle and the basket.Tthat I just use a small flat tip screw driver and finger, trap it and lift carefully out. If the coins are underneath the basket then its more involved. First, tape the door down and lift top cap and prop up aside. Then remove tubs cap off of tub. Next inside basket in the center, remove center cap off of paddle. Then remove bolt from center. Remove paddle." This I use a screw driver small enough to fit in paddle holes, one on each side to lift equally,back and forth." You will find six phillips head screws under paddle you need to remove. This should be able to lift the basket out. Walla!! T
here's the bottom of the tub and anything lying there should be removed. If you want to really inspect it there are two 5/16th head screws that hold a protective plastic plate that should be removed and checked sense your there any ways. good luck to you and hope this helps.
Feb 21, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
How can I replace the drum paddle on my zanussi zwf16070w1
Insert a screwdriver into the fourth hole in the lifter (paddle) and
bend back the anchor tabs. Pull the lifter outwards (towards the door) and detach from the drum. To insert the new lifter into the drum is needed to disconnect the tube between the tub and filter housing, than tighten the screw (through the hole in the tub) to secure the lifter to the drum.
Dado
Nov 29, 2014 | Zanussi Washing Machines
Drum paddles replace
Assuming the paddles are attached with nuts/bolts I would suggest using Locktite. If that is not an option, lock washers. If the paddles do not attach using nuts/bolts, invest in some high end epoxy.
Dec 16, 2013 | Washing Machines
Can I remove my fins on my paddle board?
The fins can be easily removed to transporting the paddle board, however they are used for navigation of the water so you should not try to paddle board without the fins attached.
Jan 17, 2013 | Water Sport
MY Estate TGDX640JQ Gas Dryer PROBLEM IS AS FOLLOWS ALL THE CLOTHING GOT BLACK SPOTS ALL OVER (DOESNT COME OUT ) SOMEONE SAID ITS FROM THE DRUM! ANY ADVICE?
It could be your washer leaking oil into the tub
Check paddles inside dryer drum for looseness if something oily got under
the paddles it will leak onto the clothes
Check felt strip at the back (and front) of the tub if it came off it could transmit junk into your dryer
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Estate TGDX640JQ Gas Dryer
How do i fix a paddle on the drum? I have zanussi machine. Paddle broken off. If i buy a new paddle how do i fix it on? Have tried to glue old paddle with no success!!
With some of these machines now they have sealed drums.On some models you can access through the bottom sump hose and others you may be able to get access through the hose by the soap box.There are a couple of drums where you can drill a hole in the top to get at the tags on the paddles and some drums where you cannot do without changing the complete tub.
Hope this helped.
May 17, 2010 | Zanussi FJD1466W Front Load Washer
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Maytag MLG23PD Gas Commercial Dryer Logo
22 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
