Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Light Engine for PT-50LC14?
What is the part number for the light engine for Panasonic PT-50LC14? I believe it uses the Toshiba TALEN 720p DLP Advanced Light Engine, but I'm sure. Help!
  • 3 Answers
SOURCE: grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Posted on Jun 04, 2008
SOURCE: OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Posted on Nov 04, 2008
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Posted on Jun 02, 2009
techman
  • 3130 Answers
SOURCE: panasonic pt-50lc14 replacement lamp. i
it is described in the owners manual. If you do not have the owners manual you can get one for free off the panasonic website
Larry Dillon
Posted on Aug 05, 2009
johnnydiode
  • 647 Answers
SOURCE: Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Tip
Panasonic PT50LC14 Manual Download
Download Panasonic PT-50LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-50LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-50LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My panasonic pt-50lc14 turns off the power light flashes red and temperature light flashes.
Examine the lamp first and be aware the model 50lc13 and 50lc14 which are almost identical had all sorts of problems----the lc13 was part of a massive recall/exchange that cost Panasonic tens of millions of dollars.
could be lamp or even the ballast which was the real issue involved in the recall.
Aug 27, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Color is only shades of blue on screen. Is it a lamp? and if so is it easy to replace
No problem is not your Lamp,Light engine opitcal block will cause this,alot of time Dmd module and light engine are replaced at same time.
Call Encompass Parts for Prices 1-800-638-3328
These are not cheap parts .
Mar 23, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Have yellowish brown discoloration around screen that remains constant, getting larger. More noticable on B&W shows and light colors are shown. Had someone come out to check and said it was the LCD...
You need a new light engine. Call another servicer. This guy ???. No lcd drive unit in there. A good servicer will be able to do this repair in your home also. Does not need to go to shop. very simple repair but costly. Call Panasonic to see if they will help. You never know.
Nov 03, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Anyone know how much a light engine might cost for this tv panasonic PT-50LC14 50 In.
to be honest save your money and buy a new tv, by the time you purchase it and install it , your still gonna run into more problems.
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 has evenly spaced vertical blue lines aproximately 1 cm apart
it's not the light engine it'sd the bulb, replace that first, then clean it all out then go from there........
Nov 07, 2008 | Panasonic PT-50LC14 50" Rear Projection...
GREEN TINT
It is almost certain that the light engine is your problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Dec 14, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 LCD rear projection
well it gets real compicated, if you are good with electronics and can take apart and put back together the inside the projector needs cleaned or the easy fix replace light engine about $600.00 rebuilt
Oct 07, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
