Question about HP Photosmart 733 Digital Camera
My camera stopped working!!!
I turn it on, and I see the top with all the symbols, but the lcd does nothing, the lense doesn't even try to come out, no sound. The right light in the front might come on for a sec, but thats it. I can't believe it died! I have had this camera for like 3 years. That is a horrible shelf life! Can anyone help? Is there a way to reset it or something?
  • 3 more comments
  • momboy1 Dec 28, 2007
    please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Jan 22, 2008
    same exact problem and I've only had it 2 years!!! I'm disgusted!
  • gtrdrum Sep 04, 2008
    The camera stopped working all together. Its totally dead, and the lense came out and stayed out. New batteries in still dead.
  • Anonymous Sep 15, 2008
    Replaced batteries, but the camera will not turn on at all.
  • Anonymous Mar 15, 2009
    My camera just quit working. I had just finished loading pictures onto the computer and it just shut off and won't come on at all.
    I took the batteries out and replaced them. I took the memory card out
    it still won't work,
    Problem Solver:
  • 19 Answers
MADE IN CHINA
Posted on Feb 23, 2008
I have the aperture at the lowest number but when I look into the viewfinder everything is dark and when I turn the aperture to lighten up the viewfinder it gives the fee
It sounds like the mechanical lever in your camera that normally couples the aperture to the camera to lock it to the widest opening for focusing is locked into the fully closed position, or that the electronics are not allowing the lens to open to fully open, depending on the type of lense being used.
Also, it could be an issue with the lense.
The simple way to test this will be to remove the lense, and to rotate the aperture ring while looking through the lense. If you see the aperture getting larger/smaller the lense aperture is fine. If it is not - the lense is damaged and needs to be replaced, or at best serviced. This can be done through Nikon, a local shop if you have one, or through online shops, I'd recommend KEH Camera in Atlanta if you have to go that way.
To test the camera side, if the lense appears to be working is also simple for the mechanical lever. With the lense removed, hold the camera in front of you looking into the lense mount. On the left side, you should see a small lever like piece. With your finger, see if this piece will move downward - it is spring loaded and should smoothly go down and pop back up. If it doesn't go down, or doesn't spring right back up, then the issue is on the camera mechanical side.
If both of those check fine, you may try a manual focus Nikon mount lense if you have access to one - to eliminate the camera electronics from being an issue, and the lense from being an issue as if this lense doesn't work, it's a mechanical issue. If you have access to another AF lense you know is working, and it doesn't work on your camera, you've narrowed it down to either the mechanical lever, or the electronics.
Most likely culprit is the lense itself.
Aug 26, 2011 | Nikon N65 35mm SLR Camera
A frozen digital camera
have you tried removing the battery at all?
May 14, 2008 | Cameras
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
Memory card not recognized, lense won't retract, menu doesn't work
I put in sd card and it says processing and does nothing wont even go off you have to open the battery place but it will take pic with no sd card in it on the internal memory
Jul 17, 2011 | Kodak EasyShare Z1015 IS Digital Camera
I have a SANYO VPC-T1060 i accidentally dropped it and it turned off with the camera lense out , i tried to turn it on but it wont
Usually when a digital camera has lens issues, they will turn on very briefly, then turn off. Try holding the bottom button in on the lcd side as you push the power button to see if your camera will display stored pictures. My daughter dropped her boyfriends 1060 in muddy water the other day and I cleaned it enough to get it to show pictures but couldn't get the lens to work. A drop or a speck of dirt will stop the lens from working. Haven't had much luck getting lens unstuck, but have replaced the lens unit, usually better to buy new camera unless you are very handy and can find a 1060 with a good lens and bad LCD, which I have done a few times. Looking on Ebay, most of the 1060's being sold 'as is' have bad lens and good LCD's......not good for us....hope this helps.
Apr 19, 2009 | Cameras
Lense stuck
You have a cracked or stripped gear. If you ever took it to the beach it likely got sand inside. Even a little. You should try blowing out the gaps with compressed air from a can of air duster. If that doesnt work, you need it repaired
Feb 02, 2018 | Kodak EasyShare C663 Digital Camera
I have an olympus digital camera fe-170. when i turn on my camera, the lense come out and the LCD screen is black, when i try to turn it off, it doesnt turn off, but after like 10 seconds it turns off by...
The lens is bad, needs to be replaced. Maybe purchase camera on ebay with broken LCD but good lens. Replacement can be time extensive. Will need #00 or #000 phillips screwdriver and solder iron. Remove 6 exterior screws+2 inside battery door. Take off front panel, remove top screw holding back panel; remove back panel. Remove 2 screws(left side top & bottom)from LCD, unplug LCD by flipping hinge up on plastic connector, pull ribbon. Remove 6 screws along outer edge of electronic board + 2 screws behind lens. Unsolder 2 battery connectors near top right side(do not melt or burn ribbon in between them). Disconnect ribbons at top right and on left edge of board. Flip board over to the left side carefully as it's still connected by 4 thin wires. Remove 3 outer screws holding lens, remove lens. Replace with good lens. Assemble camera in reverse order.
Good luck and be CAREFUL!
Loren
Jun 15, 2008 | Olympus FE-170 Digital Camera
Changing lenses
hmm the correct way is to turn the lens to te left by pressing the release button, and keeping it pressed untill the lens is of (either turn the camera on the back, facing the NIKON brand on top , te bottom of the camera away form you and the internal flash and front lcd towards you
Jun 08, 2008 | Nikon D50 Digital Camera
AF and shutter release failure
There was a lot of discussion of this when the Mk II was new. Many people "fixed" it doing just the things you did. Also, some reported that mounting the lens on another camera "fixed" it. IIRC, in the end it ended up being a lens issue. IS module. Canon can repair.
Mar 19, 2007 | Canon EOS-1D Mark II Digital Camera
Pentaxs50 turns on lense does not extend memory full displays on Lcd then it turns off.
throw it in the garbage and get a less expensive Samsung digimax s500 for less with better quality and features.. What a mistake in purchasing a Pentax. I wrote to Pentax for I had the same problem. Answer, send it in for repairs with a cost if it is not undaer warranty. Not even a hint as to what may be the problem from them! Pentax, No thanks!
Oct 22, 2006 | Pentax Optio S50 Digital Camera
HP Photosmart 733 Digital Camera Logo
93 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
