Trying to unrestrict the NAT on this WLAN box so that I can connect to others with games. When I connect to some with XBOX Live i get the statement that my NAT is too restrictive. Help Please
  • 173 Answers
SOURCE: Change NAT to open
The ports should be opened only in the router not in the x.box, go to a working pc..
To allow traffic from the internet to enter your local network, you will need to open up ports or the router will block the request.
Because our routers use NAT (Network Address Translation), you can only open a specific port or ports to one computer at a time. For example: If you have 2 web servers on your network, you cannot open port 80 to both computers. You will need to configure 1 of the web servers to use port 81. Now you can open port 80 to the first computer and then open port 81 to the other computer.
  • Step 1 Open your web browser and enter the IP address of your D-Link router (192.168.0.1). Enter username (admin) and your password (blank by default).
    Step 2 Click on the Advanced tab at the top and then click Virtual Server on the left side.
    Step 3 Check Enabled to activate entry.
    Step 4 Enter a name for your virtual server entry.
    Step 5 Next to Private IP, enter the IP address of the computer on your local network that you want to allow the incoming service to.
  • to check ip in your pc.. go to start menu click run.. type cmd and hit ok
  • in the black window enter ipconfig and hit enter, you will find the ip address
    Step 6 Choose Protocol Type - either TCP, UDP, or both. If you are not sure, select both.
    Step 7 Enter the port information next to Private Port and Public Port. The private and public ports are usually the same. The public port is the port seen from the WAN side, and the private port is the port being used by the application on the computer within your local network.
    Step 8 Enter the Schedule information.
    Step 9 Click Apply and then click Continue.
  • This would fix your problem..
    Posted on Nov 16, 2007
    i have the same problem, ive looked at the thread its the same as myne but when i go on the virtual servers it doesnt say discription or imbound port it just says lan port publick port i dont understand :(
    Posted on Feb 11, 2008
    acdr
    • 1913 Answers
    SOURCE: how to fix nat on xbox live
    type "msconfig" in run
    then startup then disable all.
    then aply ok
    then restrt .
    thats it.
    Posted on Nov 15, 2008
    Hardtack
    • 46 Answers
    SOURCE: How do i change my NAT connection from moderate to open
    This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
    Posted on Feb 10, 2009
    Go to your router admin panel and into advanced settings and set UPnP (Universal Plug'n'Play) to enable. If that doesn't work then manuallyopen the ports on the IP assigned to your Xbox. Opening NAT all the way is never a good thing. it opens you up for attacks. So with the above mentioned solution, either way, you should game on well!! Go forth and frag!!
    Posted on Apr 12, 2009
    My xbox is telling me that my router's NAT setup is on moderate. what does that mean? and how can i fix it?
    Here is Microsoft's definition of a moderate NAT and their suggested fixes.
    http://support.xbox.com/en-US/xbox-live/connecting/nat-type-strict
    Dec 24, 2011 | Microsoft Xbox 360 Console
    When trying to connect x box and use xbox live keeps coming up with nat restricted this has only lately been a problem old box worked ok
    XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console
    click here to download repair guide
    Dec 21, 2010 | Microsoft Xbox 360 Console
    Im trying to play xbox live on MW2. Its not letting me play because my nat is strict. I have tried to change it but i dont have an ip adress. If i do it is not showing. I have dsl and i am hooked into the...
    If you are not able to connect to Xbox Live because of your DSL connection, you need to contact your DSL provider and ask them to unblock or unrestrict it.
    In general to reset the settings you can go to 192.168.1.1 and that will allow you to log in and change the settings yourself without having the contact the DSL company.
    Nov 17, 2009 | Motorola Computers & Internet
    Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
    There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
    Sep 22, 2009 | Microsoft Xbox 360 Console
    I want to open my NAT so i can play xbox live
    Okay. If you look at Network connections on Start menu (XP) open network connections...
    Then select the on you are connected to... (LAN or WLAN) Click the support tab and you will see something like "192.168.1.1"
    Well type that into your browser, if it ask you for a password the default is normaly "admin" or "1234" (No quotes)
    Temper with the "Gaming" or "Wireless connections" or "port forwarding"
    If that does not work, are you sure you got xbox live gold?
    (or hit the reset button on the back of your router)
    Apr 28, 2009 | Computers & Internet
    Change NAT to open
    First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
    Mar 13, 2009 | Dynex DX-E401 Router
    Change NAT to open
    You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
    Feb 09, 2009 | Linksys WRT160N Wireless Router
    Cant chat to 1 of my freinds on xbox live
    What is their internet connection speed?
    Your friend may not have port forwarding on their home network and the network router filters the Internet NAT redirection...
    Setting up a DMZ (Demilitarized Zone) on the router for the Xbox gives it unrestricted access to the internet; also puts your Xbox outside you routers firewall.
    DMZ ports have to be programmed manually and the IP address also must be manually entered; The DHCP Automatic IP address puts the Xbox back behind the firewall; just duplicate the automatic DNS Server settings and the Netmask. Then choose a IP address outside the Automatic IP range (e.g. 192.168.1.175)
    If that does resolve the issue see if the other Xbox needs a Live Update.
    Nov 28, 2008 | Microsoft Xbox 360 Console
    I'm trying to connect to xbox live over a laptop but it wont let me connect! What's up?
    This site has good guides relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
    [url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
    Jul 03, 2008 | Microsoft Xbox 360 Console
    Halo 3
    make sure your NAT is open, you can check this by running a connection test on your console. there are 3 types of NAT connection. Open, Moderate & Strict.
    Open being the ideal option, strict meaning lots of problems connecting with talking and finding other players on xbox LIVE.
    NAT settings can usually be found on your routers setup / settings page (usually http://192.168.1.1 ) but some routers may not have setttings for your NAT.
    hope that helps
    Anthony Kinson
    Apr 21, 2008 | Microsoft Xbox 360 Console
    265 people viewed this question
    k24674
    jasbo
    jasbo
