Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
No forward thrust -- can hear a clicking noise in unit when stepping on foot pedal.
  • 76 Answers
Usually this is due to a power problem. More times than not I have seen this problem and it seems to always point to a connector that has come off internally (electrical push on connector). Also check the battery cable wires for corrosion and tight fitting wire.
The issue happens with vibration and the heating and cooling of the connectors. If not solved sooner than later, you'l run into all sorts of (expensive) problems.
Here's a schematic for you motor. Go over it and check all connectors:
Max 55 Bowmount
Hope this helps!
Mike
Posted on Sep 26, 2009
My Ford KA 2006 starts to make a rattling noise whenever press down the clutch or change gear while driving. Any reason?
Sounds like the thrust washer that activated the clutch is worn. Usually caused by constant resting ones foot on the clutch pedal.
Jun 07, 2017 | Ford Cars & Trucks
MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
Sep 21, 2008 | Minn Kota Maxxum 80 Freshwater Bow Mount...
When i press the clutch pedal down it makes a rubbing noise similar to worn brake pads.stuart
opel vectra ,,,,ot sure if their is a automatic adjustment on the pedal ,if so it could be this failing which the cable could be frayed ,would really need to see it to know for sure
Feb 08, 2016 | Opel Vectra Cars & Trucks
When using the foot pedal for forward playback to transcribe, when you lift your foot to stop the tape continues forward for about a second.
It sounds to me that you might have a mechanical problem in the machine. I am not familiar with this machine, but I have worked on lots of tape machines. The belts and rubber pieces can get slick or stretched causing problems.
Oct 24, 2017 | Sony M-2000 Microcassette Transcriber
I hear a cclicking noise when I step on break when key is on. I don't hear the click while car is running. Its a 97 infinity q45
Most automatics have a lock on the transmission selector.
When the vehicle is in P (Park) you are not able to select drive or a gear unless you depress the brake pedal.
My Audi Q7 ha a solenoid and you hear it click when I put my foot on the brake.
This solenoid stops you from accidentally selecting a gear without the brake depressed.
Is it a single click when you depress the pedal.
Or is it a constant click click click ?
Apr 28, 2015 | Infiniti Q45 Cars & Trucks
Bad front end vibration while in gear at idle only makes dash and floorboard vibrate
When you are in gear at idle with your foot on the clutch you have placed an axial load on the crank which is pushed forward in the main bearings against a thrust bearing. I suspect a failing thrust face on this bearing as it only works under a clutch release load. The only other point that is under load is the clutch throw out bearing but if that is failing you should be hearing a tinny type of rattle when you have the foot on the clutch
May 05, 2013 | Mitsubishi Galant Cars & Trucks
It wont turn on, everytime i stepped on foot padle, i hear click,but nothing happen, when i press on GFCI test switch,the orange light come on, i don't know what's wrong?
The orange light on the GFCI is telling you there is a low-grade short from HOT to ground. There's a loose or frayed wire hitting metal somewhere!
The foot pedal is MY suspect.
Jan 29, 2011 | General Wire MR Mini-Rooter Basic Unit
1999 honda prelude manual transmission isn't disengaging all the way when i shift, sometimes locking the shifter in gear or not allowing me to up or down shift. I know my master and slave cylinders need to...
This depends as dose it do it when cold or hot.
2nd when you push in pedal and put in gear dose it go in clean or hard to select 3rd can you hear a grinding noise when pushing in pedal and noise goes
when you take you foot off the clutch pedal IF so then its the thrust bearing on clutch REPLACE ALL .4th if you push in clutch pedal and select a gear and let the clutch out if drive right out (replace)
Sep 27, 2009 | 1999 Honda Prelude
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
307 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
