Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
The drum is making a thumping noise like it is out of round
  • 64 Answers
SOUNDS LIKE DRUM ROLLERS ARE BROKEN
Posted on Sep 25, 2009
  • JAMES Sep 25, 2009
No kidding. Really? I think the title is "best solution" and no "most obvious answer". Anyone have any direction or referral to a site that shows the Maytag service manual for this dryer?
Posted on Oct 05, 2010
Maytag dryer
If this is the metal drum model of Maytag dryer, then the drum is likely out of round and will be evidenced by a broken spot weld on the seam where the drum is welded. I have had to replace mine for that very issue. Not cheap! Hope that is not the case for yours, but just rotate the drum by hand and you will see a high and low spot during the rotation. If the high and low spots are consistent, you know your drum is out of round and likely has busted spot welds. You can run it like that for a while if you can stand the thumping. If no out of round condition, then check the roller alignment and see if the bracket got tweaked not allowing it to rest on the drum. Again...if it touche s the drum and then leaves the drum as the drum is rotate by hand, the drum is out of round. Hope this helps
Feb 15, 2017 | Maytag Dryers
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Dryer Model # LER4634EQ1 As the drum turn's the
What the most probable things thats causing that noise is the rear drum support rollers.
This youtube video will show ya how to take apart the dryer and replace those rollers
http://www.youtube.com/watch?v=wBf_vwvlFGM
The part number for the rollers is 349241T that part number is a kit for both of the rollers in one kit plus the plastic triangle clips that hold them to the shaft they fit on.
That part can be purchased at your local appliance parts store or also online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 12, 2011 | Whirlpool Dryers
Dryer making a thumping noise, heating okay, drum is going round. could drum be out of round and thumping on the rollers
the roller is out of round instead for the internal bearing has dried up and locked tight making the belt to burn the nylon roller flat in the spot the belt rides on. It will be neccessary to replace the belt and the roller as well
Feb 20, 2010 | LG DLE2532W Electric Dryer
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
569 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
