Question about Samsung HLN467W 46" Rear Projection HDTV
I have a Samsung HLN467W That work for a while then the Temperature light comes on and the set shuts off. If I leave it unplugged for a while.... then plug it b ack in it works fine.
  • Samsung Master
  • 5,138 Answers
Ck your Fans if they stop running set shuts down to protect Lamp from burning up you may have a defective Fan. Or Clean Fans if dirty that to will stop set from playing
Posted on Sep 25, 2009
Testimonial: "Thanks I will give it a try"
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
I have a samsung HLN467W DLP and when I turn it on it just makes a loud annoying beep that stops and starts. TV shuts off and then turns back on again and repeats the beeping. The TV on/off sequence stops...
if all three lights on the front blink when it stops then yes. you can removed the colorwheel and inspect it most of the time if the sound is loud the colorwheel is shattered
Mar 19, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Reset tv samsung
Unplug,replug about an hour later should reset it self to factory setting.
Dec 15, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN467W Flashing "LAMP" LED
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Sep 03, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Turning On Problem
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 06, 2008 | Samsung HLN467W 46" Rear Projection HDTV
No picture no sound
this is most often caused by a faulty lamp or faulty ballast. try resetting the tv by unplugging and leaving it unplugged for 5-10 minutes or so, plug it back in and check it.
you should be able to find the replacement parts via partstore.com
ballast is part number BP4700017A
lamp is part number
BP9600224A
compatible cheaper lamp part number
BP96-00224ARL
hope this helps,
trin
Nov 19, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung 46" DLP
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN467W 46" Rear Projection HDTV Logo
303 people viewed this question
Henry  Thomas
Henry Thomas
