Question about AudioBahn AW100T Car Subwoofer
How do i know if my sub is blown? - AudioBahn AW100T Car Subwoofer
  • 344 Answers
The sound (if it makes any) will be distorted and garbled. Keep in mind that subs require amplification. If you are testing the sub without an amplifier you may or may not hear distortion because the radio by its self can't make the sub perform properly, if it has to low of voltage it may crackle because its not recieving a strong enough signal, if it is blown it may not crackle for the same reason
Posted on Sep 27, 2009
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
No high output to the connected speakers
Speaker may be blown, pull it from the case and connect a spekaer wire you know is working to the sub, if no sound its blown. If sound then you have a problem with the connections or the sub pwer from the stereo.
Jan 22, 2010 | Cerwin Vega LW10 Subwoofer
No sound coming out of the subwoofer not blown either what could it be?
we need a little more information to help out here...how do you know the sub isnt blown? why type of sub/amp/ radio? any lights on the amp? what color? is the amp powering on?
Nov 24, 2009 | Rockford Fosgate Car Audio & Video
Kicker L7 Blown??
voice coil is burnt blown speaker sorry
Aug 20, 2009 | Q-Logic QLT-.3508SS Car Subwoofer
I have 2 AW1206T's how do you know when their blown?
when a sub is blown it usually makes a scratcy or grinding noise if you push the sub in but if its blow it realy wont make much of a sound so it sounds like your voice coil is going out you will want to get this looked at quick or it can get expensive...i had one were it was cheaper to buy a new sub rather than fix it. it can also just be it disorting from too much power. i would never go over the power limit when dealing with 3000 watts, that can get realy expensive quick
Apr 12, 2009 | AudioBahn AW1206T Car Subwoofer
Blown solobaric?
how did he messed up? anyways, if u push the cone of the sub down and u hear a sound like "TUN!" its most likely ur sub is irremediably damaged. The cone needs to come up perfectly as a good sub would do. I need to know exactly what ur friend did b.c it is quite weird to mess a good sub by slightly switching cables
May 24, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My amp works but my sub doesn't...!!!????????????
Whats the condition of your amplifier? New , Used, Old?
You might have a blown channel off your amplifier, this may cause little or no sound. You will have some distortion, crackle sound and then maybe nothing at all. What kind of subs are you running to it? Make sure the subs arent blown and check the voice coils to see that they are not torn off the subs , these are the 2 little silver or copper wires that are connected from the speaker connectors to the sub itself.
Let me know what happens?
Oct 21, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Aug 05, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
AudioBahn AW100T Car Subwoofer Logo
371 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
