Everytime the phone rings my wireless connection goes away. I am also unable to secure this network. the model number is f5d8235 4
    President:
  • 1,187 Answers
Your phone is using the same frequency as the wireless router (2.4GHz). It would be very difficult to prevent this unless you change:
1. Phone to corded system.
2. Change phone to cordless DECT (5.8GHz) system
3. Change network router from "G" series to "N" series.
Posted on Sep 25, 2009
    Scholar:
  • 131 Answers
Hi there, you have a 2.4 Ghz cordless phone I am betting! I would recommend upgrading your phone to a higher frequency like 5.4 Ghz. The wireless routers use the saem frequency as the cordless telephone does.
Hope this helps
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
LGP350 Wireless connection issues
Log onto your router. Then find the wep code or wireless security code.
Enter the code into the lpg350 wireless setup menu.The code is either 16 or 25 letters or numbers long.
Dec 21, 2011 | Video Game Consoles & Games
Im trying to connect my printer via wifi but am unable to locate it on my laptop?
The printer itself has to first be configured to connect to your wireless network itself, if you do not have a secured network then the process is usually as simple as going into the menu on your printer and telling it to search for networks, if your network is secured (wireless devices require a password to get internet access) then you will have to enter the password into the printer as well.
hope this was helpful. If you provide the model number of the printer I can walk you through the setup.
May 30, 2011 | Compaq Computers & Internet
Contant need top reboot the program
Do a wireless scan on your computer and out how many wireless access is in your neighborhood. More than likely that your router is sharing the same wireless channel number as your neighbor's. Go to your router and cheange to opposite of what your neighbor is on.
Dec 20, 2009 | Linksys WRT160N Wireless Router
My netgear rangemax does not emit a steady wifi signal. if i plug in my computer, the internet is working fine. all of the lights are on on the router. The wifi network shows up for a few minutes, goes...
Intermittent wireless connection can be caused by different factors, such as:
1. Wireless interference within the network. For best results, place your router:
- near the center of the area in which your computers will operate.
- in an elevated location such as a high shelf where the wirelessly connected computers have line-of-sight access (even if through walls).
- away from sources of interference, such as microwaves, and 2.4 GHz cordless phones.
- away from large metal surfaces.
2. Wireless settings on the router are still set to default. This may cause conflict with other Netgear routers within your network range.
- change the router's SSID or wireless network name.
- change the router's channel.
- enable wireless security on the router.
3. If the wireless connection is still unstable after performing the steps above, it is possible that the firmware is corrupted. Upgrade the router's firmware.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Heath Zenith 6150 wireless doorbell
Yes, there is a way to change the security code. See FAQ here:
http://www.heath-zenith.com/servsup_disp_faq.cgi?cat=5
click on "how can I change the security code."
Jan 06, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Unable to connect Ipod Touch to Internet via Wifi
im no sure wa kind of router i have, bu iam sure that i have the right password and i comes up with the networks i could connec to and i try connecting to my home 1 and it comes up "unalbe to connect to this network" my sis or my mum can connect either we all have ipod tocuhes and its getingfustrating. can any one help?
Nov 16, 2008 | Belkin (F5D7230-4) Router (587009)
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot connect to my new WRT150N router
Lets start with the basics. First do you have a computer with an ethernet port for a wired connection? If so connect it to the router and attempt to access the internet. If this works we have eliminated the ISP connection and need to address the wireless configuration of either the router or the adapter or both. I will need the version number of the router which probably appears on a label on the bottom of the device to get access to the proper users guide. I do not have one of these models specifically however on reading the specs it mentions that it works well with B and G wireless cards -- there is a possibility this device will not work with A band cards -- we will confirm this later. Please provide the model number for wireless adapter so we can research them if needed.
Nov 29, 2007 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
