Question about HP Compaq Presario V2000 Notebook
Upon turning on my comouter i hear two beeps and then it goes to a gray/black screen that gives me two options "press F1 to resume , F2 to setup. I have pressed both and nothing happens
  • mntallman Sep 25, 2009
    I have a lap top, compaq presario v2000. When i went to reboot my computer today, it wont reboot. It goes directly to a black/grayish screen and gives me two options to resume, or to setup. I have prssed F1 nothing happens and i have prssed F2 nothing happens. AFter a while the computer just shuts off.
  • rahat faraz May 11, 2010
    Solution chack on this site www.solve.tk
  • 137 Answers
The beeps are a BIOS error code. 2 beeps means that there is either something wrong with the RAM or the motherboard.
The best way to tell (if you have 2 RAM chips installed) is to remove one of the RAM chips and try to boot again. If the same happens then swap them with eachother. If it happens again you will have to purchase a new RAM chip from a store that will let you try it then return it if it doesn't work.
If you still get the same result with the new RAM then its a motherboard problem. If the laptop is still under warranty it should be covered. If not it's best to trash the laptop and get a new one. A motherboard replacement can cost almost as much as a new laptop.
Posted on Sep 26, 2009
  • 2,229 Answers
This a memory parity error.
It is telling you your memory is bad. Try replacing the first stick of RAM and try to boot again.
If your computer has built-in memory, it means a new motheboard.
Posted on Sep 25, 2009
  • Art Ellison
    Art Ellison Sep 26, 2009
    You first said that it gave 2 beeps. As I said before, this indicates a memory error and your computer will not work until you address that error.
How to skip bios setup
F2 is your BIOS Setup enter key?
As SOON as you press the Power On button, start tapping on the F2 key.
Tap in 2 second intervals.
You may hear beeps. These are Stuck Key Error code beeps. You know what they are now, so just ignore them.
The BIOS Setup screen goes by F-A-S-T. You have a very small window of opportunity. This is why you are tapping on the enter BIOS Setup key, as soon as you turn the laptop on.
In BIOS Setup there is an option to bypass the P.O.S.T screen.
For additional questions post in a Comment.
Regards,
joecoolvette
May 21, 2012 | Computers & Internet
This problem just started yesterday.When booting up,the first screen with the white bar goes across,then it goes to a black screen and beeps once with the message,hit F1 to reboot or F2 to setup menu,but...
restart your computer press F8 then click restore the directory setting this will restore all the directory in the system and the system will reload properly if this doesn't work you will have to re install the OS
Jun 28, 2011 | Dell OptiPlex GX110 PC Desktop
Ok so my netbook goes to a blue screen where it says " press f2 to run setup, press TAB to display BIOS POST message" and stays there. if i push f2 then it goes to a black screen where at the...
Probably the hard drive is dead. Did you drop it recently? Anyway, it could be just the connector, if your good with hardware you could open it and check. I would suggest you to use the warranty though.
Mar 03, 2011 | ASUS Eee PC 1000HE Netbook
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
ACER ASPIRE 3680 --OPERATING SYSTEM NOT FOUND
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
My Acer Apsire 5100 will not power on properly. The acer screen (white and blue screen) will almost progress fully. Then, you hear two high pitched beeps and an error screen that says: "system bios...
Your operating system has been corrupted. At this point, you have to get all your information transferred onto another computer and then do a clean installation of the operating system of your choice.
Jan 18, 2010 | Acer Aspire 5100 Notebook
Cant See Post
The 2 beeps are an error code. It can mean a couple of things; 1. Bad or improperly seated RAM; or 2. Bad or improperly seated video card. The F2 option will take you into bios setup. But I would try the video card option first as it is the usual culprit in this situation. Hope this helps & please rate this solution fixya. Thanks.
Feb 06, 2009 | Compaq Presario M2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Blank screen on start up
It means that your system cannot detect Windows on your hard drive. Check the connections inside if you can. If everything is connected properly, then your hard drive is probably is at fault. You can do a disk check in dos but may not be accurate.
Oct 30, 2007 | Compaq Presario M2000 Notebook
HP Compaq Presario V2000 Notebook Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
