Question about Goodmans 15.4 in. LCD TV/DVD Combo
Remote will adjust volume, show menu etc. but will not select play or forward/reverse etc.
How do we adjust color without a remote ?
Hello
If your TV has a "Menu" button on its front panel, press it once to get into its menu option. Surf thorogh and come to the picture control window. There you can see the adjustments. Will be Brightness, Contrast, Colour, Sharpness, Tint etc. Select the option you want to adjust, advance or decrese its parameter by volume Up/Down buttons. If there is no 'Menu' button on its front panel, it will be impossible to adjust these parametes withoug a remote control. OK.
Jul 24, 2011 | Televison & Video
How do I turn off the ringer to my vtech, model6032 telephone.
Ring volume
The handset ringer volume can be adjusted from five levels.
• Press MENU/SELECT to display menu when in idle mode.
• Press up arrow or down arrow to reach Setup HS. Press MENU/SELECT.
• Press up arrow or down arrow to reach Ring volume . Press MENU/SELECT.
• Press up arrow or down arrow to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
• The screen displays Stored and you'll hear a confirmation beep.
You can adjust the ringer volume by pressing VO L+/VOL- on the
telephone base when the telephone is ringing.
Jun 30, 2011 | Vtech 9009111 Cordless Phone
Hey there just have simple question: Is it possible to lock setting for the different modes? I have found that a little brighter for movies and games works for me but I think that it keeps switching back...
Hello
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
1 Press MENU on the remote control.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK
to enter the setting.
4 Adjust the picture quality.
The following picture settings can be confi gured. Depending on
the format of the picture source, some picture settings are not
available
You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you
turn off the unit.
You can set the location of your TV to [Home] or [Retail store].
Choosing [Home] gives you full fl exibility to change predefi ned settings for
picture and sound.
1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to
select [Setup] > [Installation] > [Preferences] > [Location].
2 Select [Home] and then press OK to confi rm your choice.
3 Press MENU to exit.
Mar 23, 2011 | Philips 55PFL7705D 55" LCD TV
Which button is which
On the top of the device are the recording indicator and built-in microphone. On the front of the device to the right of the screen: (from top to bottom) ERASE, MENU, VOLUME UP, VOLUME DOWN
The MENU button cycles through these options in this order: Folder, record condition, record quality, AVR on/off, play condition, beep tone, set year/day/12 or time, key lock on/off
On the right side of the device: (from top to bottom) RECORD, STOP, PLAY, FORWARD*, REVERSE* *(FORWARD/REVERSE can be used in the MENU mode to select options)
On the left side of the device: (from top to bottom) External microphone jack Connects headphones
Here is an online (*.PDF format) manual for the recorder: MANUAL
I hope this information helps! :-)
Mar 06, 2011 | RCA RP5020 Digital Voice Recorder
Just bought one of these used and need to adjust the color brightness contrast etc. I assume I do this thru the "menu" option. I don't have the original remote with the unit and I can't get any universal...
Try website like Remotes.com to buy the original remote it ur best bet.Tries the manual control on the tv.Push the Menu button use the channel + - and the volume + - on the manual buttons to adjust colors,contrast,brightness.
Jul 04, 2010 | GE 13TVR62 Combo
What happened to words like Volume, Play, etc. I
They're called icons and they've been standaridzed since cassette decks were state of the art. It makes manufacturing easier if they don't have to dela with different languages.
|| = pause
> = Play
< = Reverse
>> Fast Forward
<< Rewind or Fast Reverse
square = Stop
May 16, 2010 | Audio Players & Recorders
Toshiba 23HLV85 LCD TV/DVD inverted image
Yes,Ur main Tuner board have problems,the ICS on the board is not coverting.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 14, 2010 | Toshiba 23HLV85 Television
How do you get your 6700 to play music etc on the headphones
Your phone includes a media player for listening to songs and viewing video clips. Music and video files stored in the music folder in the phone memory or on the memory card are automatically detected and added to the music library.
To open the media player, select Menu > Media > Media player.
Music menu Access your music and video files stored in the phone memory or on the memory card, download music or video clips from the web, or view compatible video streams from a network server (network service).To listen to music or play a video clip, select a file from the available folders and Play.
To download files from the web, select Options > Downloads and a download site.
To update the music library after you have added files, select Options > Update library.
Play songs
To adjust the volume level, press the volume keys.
Operate the player with the virtual keys on the display.
To skip to the beginning of the previous song, select icon_28.giftwice.
To rewind the current song, select and hold icon_28.gif. Release the key at the position you want to continue the music playback.
To close the media player menu, and to continue music playback in the background, press the end key.
To stop the media player, press and hold the end key.
Hope it helped.
Nov 22, 2009 | Nokia 6700 Classic Cell Phone
TV one side slight blurr
hello, here some help with this
hope this help below are adjustments
and values
How to enter into Service Mode
While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
seconds.
10.1.1. Key command
"1" button...Main items Selection in forward direction
"2" button...Main items Selection in reverse direction
"3" button...Sub items Selection in forward direction
"4" button...Sub items Selection in reverse direction
"VOL" button...Value of sub items change in forward direction ( + ), in reverse direction
Value is shown as a hexadecimal number.
 ·Preset value differs depending on models.
 ·After entering the adjustment mode, take note of the value in each item before starting adjustment.
Main item Sub item Sample Data Remark
ADJUST CONTRAST 000
COLOR 3F
TINT 03
SUB-BRT 800
WB-ADJ R-CUT 80
G-CUT 80
B-CUT 80
R-DRV E6
G-DRV F0
B-DRV FC
ALL-CUT 80
ALL-DRV FC
OPTION BOOT ROM Factory Preset
STBY-SET 00
Emergency OFF
CLK MODE 00
CLOCK 000
AGING RGBW
COUNT
ALL WHITE
ALL RED
ALL GREEN
ALL BLUE
ON/OFF
RAMP WHITE
RAMP RED
RAMP GREEN
RAMP BLUE
1% WINDOW
COLOR BAR
A-ZONE B-ZONE/4 TRIO
SCROLL
WHITE FLAME
RM-SET CODE A Fixed
SRV-TOOL - See next
10.1.3. How to exit
Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control
good luck hope tis help.
Jan 18, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Goodmans 15.4 in. LCD TV/DVD Combo Logo
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Henry  Thomas
Henry Thomas
Jonathon summesfield
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
